Fibre Broadband Speed Reduction
- Fibre Broadband Speed Reduction
26-02-2022 2:25 PM
In the past week have been monitoring the speeds both up and down and have noticed a considerable and ongoing reduction in speeds. Was consistently at 55 -60 mbps and now 30-45 mbps.
Both wired and wireless give the same reduction which is not in keeping with the product I am paying for.
Also, there is a regular (daily) loss of connection for up to 5 minutes and usually early evening between 18:00 and 21:00
I notice a lot of similar issues with other users.
I really would appreciate some feedback on the issues here.
Re: Fibre Broadband Speed Reduction
27-02-2022 4:55 PM
Hiya @dartilov,
I'm really sorry to hear that you are experiencing an issue with your connection and for any inconvenience this is causing.
Our tests are locating a potential external fault and I need to arrange an engineer visit.
Please can you update the ticket here with your availability and update this thread so that I can pick this up for you.
