Fibre Broadband Constantly Dropping Out
- Fibre Broadband Constantly Dropping Out
28-05-2021 3:01 PM
Just moved to PlusNet on Wednesday - since then broadband constantly dropping out for significant periods of time, ie, on for 2 hours off for 30-60mins. Really difficult when WFH full-time! Router light is constantly blue and the Hub Admin keeps saying we're connected. Help!
Re: Fibre Broadband Constantly Dropping Out
28-05-2021 3:15 PM
@Spikey1 Quick thought - what username is showing in the router? It is possible the auto-configuration failed and you are still identified as 'setup@plusdsl.net' - which would explain this situation.
Welcome to the forums, BTW
28-05-2021 5:54 PM
Hi John - thanks for the tip, now implemented and hopefully has fixed the problem - so far so good anyway! Will let you know how we get on.
Thanks again
Anne
28-05-2021 6:02 PM
You should be OK Anne - seems quite a few auto-configurations are failing at the moment, but you know where we are. 😁
