Speed gone again. Down from 36mbps to 10-12mbps.
- Speed gone again. Down from 36mbps to 10-12mbps.
28-05-2021 11:49 AM
Wondering if I could get some help with my broadband again. I have FTTC service that I have had for 10+ years without issue, recently I have had a load of disconnects and twice recently I have had the speed crippled. I recently had an OpenReach engineer attend site, tested the lines and found nothing wrong, reset something in the exchange and restored the service back to 30.9mbps, 0.3 above the minimum level.
Yesterday I noticed pages loading slow again and general lag, ran a speedtest from my ethernet connected server an average download speed of about 10mbps, BT Wholesale recorded a maximum of 14mbps. I have power cycled the BT modem as well as my own firewall and the speed has not recovered. I have attached screenshots of the tests.
Two of my neighbours, one of which is with Plus Net, have both been having issues with disconnects as well, is it possible that there is something else going on elsewhere that is affecting my service and bringing my link speeds down?
I am not running Plus Net hardware and haven't for the entire time that I have been with Plus Net, I have tested my hardware and found no fault at all, I have also bypassed my firewall completely by creating a PPPoE connection direct from the BT modem to my Linux laptop and run a speed test and still the same. I am not able to use the BT master socket under the face plate as the splitter is built into the face plate.
I have raised a fault on the website, however the email that I received asked me to run BT Wholesae tests and upload them using the wizard, sorry but I can't see anywhere to upload them to the ticket using the link provided. If someone could please have a loomk at this and let me know if there is anything that can be done to restore this I would be grateful.
Cheers,
Damian
Plus Net Username: Blinkydamo
Postcode: LL11 6YL
Re: Speed gone again. Down from 36mbps to 10-12mbps.
28-05-2021 12:02 PM
This topic has been moved from ADSL Broadband to Fibre Broadband.
28-05-2021 3:19 PM
Hi @blinkydamo
Thank you for reaching out via our Community Forum regarding the issues with your broadband service. I've run some tests on our end which clearly do show an issue, which is obviously having quite an impact on your download speeds. We've been advised that another engineer appointment will be necessary in order to investigate further.
Before proceeding though, we'd like you to try a few things to make sure that the source of the problems do not lie within your domain / property. I've sent you an email which contains a video of some troubleshooting steps you can take. Once you've done that, respond to the Open Fault Ticket on your Member Centre, and our Technical Support Team will be happy to follow up.
I've also included our Broadband test results below for your reference:
