Experiencing bad latency, low download speeds and disconnects for the last month
- Re: Experiencing bad latency, low download speeds ...
03-01-2020 9:43 AM
Hello,
I would appreciate it if someone could test my line, the service is unacceptable.
I am out of contract and I have extremely fast Three 4g on my doorstep.
A line test and possible resolution to the issue will help in my decision as to what I do next with broadband.
Thank You
David
Re: Experiencing bad latency, low download speeds and disconnects for the last month
03-01-2020 2:57 PM
Hello @davidmarshall15,
Thanks for reaching out to us here.
Sorry to read you are having trouble with download speeds & drops in connection, please accept my sincerest apologies for the frustration caused.
I've ran a couple of tests over your service today, it appears your speed is below the estimates for your service & the drops in connection are frequent. I would suggest following our troubleshooting guide here first, if that doesn't work please get your connection plugged into the test socket and monitor the connection for a day or so. If you still notice drops in connection after that please raise a fault here and let us know here once done.
Thank you.
03-01-2020 8:15 PM
I have tried 3 filters connected to the test socket behind the faceplate of the master socket, 2 BT Mf 50's and 1 generic brand. No joy with any of the filters.
I have raised a fault.
04-01-2020 2:00 PM
Thanks for getting back to us @davidmarshall15
I'm sorry to see you're experiencing connection problems. I can see we've passed the fault onto our suppliers and we've been advised an engineer should be going out by 08/01/20 23:59:59 to investigate further externally.
Let us know how things go over the next few days.
08-01-2020 7:15 PM - edited 08-01-2020 7:15 PM
Hello,
Open Reach have found and fixed a fault, the line is now stable but the speeds are still slow, can someone please reset the profile on this line.
David
09-01-2020 4:19 PM
