Echo Request Interval?
- Re: Echo Request Interval?
09-08-2016 11:14 AM
I notice that there's an Echo request interval in the settings of my TP-Link TD-W9980 Modem Router. Default is 30, what does it do, and is 30 the best setting?
On set up, I left all settings at default, I'm not sure if I'd get better performance setting them differently?
The Authentication Type by default is "Auto_Auth", it can be set to CHAP which is apparently right for PlusNet, would doing so improve performance do you think?
09-08-2016 4:30 PM
and echo request is basically another way of describing a ping test. ICMP sends packets to the target host and waits for a reply.
This is basically the routers way of knowing that the connection is working and what it uses to trigger a full disconnection if it believes the connection is down if it receives no response.
Some people set this to a shorter duration like 5 or 10ms if they experience issues but I'd leave it if you;re not sure.
