Ebay keeps timing out
- Ebay keeps timing out
Re: Ebay keeps timing out
27-02-2016 9:38 PM
Quote from: npr Don't see how it can be a PN issue when the listing pages are working.
Because the different sections of eBay go via completely different routes, see example in Reply #4,
27-02-2016 9:57 PM
Listings are hosted by a CDN provider in the UK:
Quote C:\Users\npr>tracert www.ebay.co.uk
Tracing route to e11847.g.akamaiedge.net [2.16.227.236]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms ZyXEL.Home [192.168.1.1]
2 22 ms 21 ms 22 ms lo0.10.central11.pcl-bng03.plus.net [195.166.130.165]
3 23 ms 23 ms 21 ms irb.11.PCL-CR01.plus.net [84.93.249.97]
4 22 ms * 22 ms ae2.pcl-cr02.plus.net [195.166.129.7]
5 22 ms 22 ms 21 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 * * * Request timed out.
7 23 ms 21 ms 23 ms a2-16-227-236.deploy.akamaitechnologies.com [2.16.227.236]
Trace complete.
Messages are routed to the US:
Quote C:\Users\npr>tracert mesg.ebay.co.uk
Tracing route to mesg.g.ebay.com [66.135.212.240]
2 21 ms 22 ms 22 ms lo0.10.central11.pcl-bng03.plus.net [195.166.130.165]
3 22 ms 21 ms 21 ms irb.11.PCL-CR01.plus.net [84.93.249.97]
4 23 ms * 22 ms 195.99.126.96
5 24 ms 22 ms 36 ms core4-te0-10-0-19.faraday.ukcore.bt.net [109.159.249.13]
6 24 ms 24 ms 24 ms host213-121-193-183.ukcore.bt.net [213.121.193.183]
7 23 ms * 25 ms t2c3-et-3-1-0-0.uk-lon1.eu.bt.net [166.49.211.236]
8 23 ms 23 ms 22 ms 80.157.129.113
9 119 ms 121 ms 118 ms was-sb1-i.WAS.US.NET.DTAG.DE [62.154.5.138]
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
27-02-2016 11:18 PM
Mind you, maybe the mobile site has different routing again... Haven't checked that...
I did check various IP addresses returned for mesg.ebay.co.uk by different DNS servers, though, and the routing seemed to be the same for all of those.
Down Detector has noticed something's up.
Troubleshooting: The Limitations of Traceroute & Ping
Latency: Connection "fast" but internet sluggish? Bufferbloat FAQ
Black Holes: Worth noting that the Plusnet Hub One router has an MTU of 1488 bytes.
28-02-2016 12:42 AM
Quote C:\Users\Home>tracert www.ebay.co.uk
Tracing route to e11847.g.akamaiedge.net [104.82.196.133]
1 <1 ms <1 ms <1 ms RT-AC68U-F088 [192.168.1.1]
4 5 ms 5 ms 4 ms 172.17.4.141
5 10 ms 10 ms 10 ms 172.17.10.198
6 10 ms 11 ms 10 ms be2.psb-ir01.plus.net [195.166.129.180]
7 11 ms 10 ms 11 ms core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
8 11 ms 11 ms 11 ms core3-hu0-1-0-0.faraday.ukcore.bt.net [195.99.127.32]
9 10 ms 10 ms 10 ms peer2-et-9-3-0.faraday.ukcore.bt.net [62.6.201.167]
10 11 ms 11 ms 11 ms 195.99.126.19
11 10 ms 11 ms 10 ms a104-82-196-133.deploy.static.akamaitechnologies.com [104.82.196.133]
Trace complete.
Quote C:\Users\Home>tracert mesg.ebay.co.uk
4 67 ms 4 ms 4 ms 172.17.4.141
6 12 ms 14 ms 10 ms be2.psb-ir01.plus.net [195.166.129.180]
7 11 ms 11 ms 10 ms 195.99.125.134
8 11 ms 10 ms 10 ms peer6-hu0-11-0-1.telehouse.ukcore.bt.net [195.99.127.13]
9 10 ms 11 ms 10 ms t2c3-et-3-1-0-0.uk-lon1.eu.bt.net [166.49.211.236]
10 37 ms 12 ms 10 ms 193.159.165.81
11 107 ms 107 ms 107 ms was-sb1-i.WAS.US.NET.DTAG.DE [62.154.5.138]
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Also when I rang the technical department asking for help and I explained I get no ping response their answer was "sorry we only go as far installing the line and if your speeds are fine then there is nothing we can do".
Because of this issue I wasn't able to use a voucher to buy goods which then expired thus I lost out money. IF PN are responsible then I hope they do the moral thing and compensate me accordingly.
29-02-2016 10:30 AM
It's an honour to have such 'special' routing on the rare occasion we need to use the site, of course(!) -- but it is also a bit of a pain; so if it could possibly be investigated, please?...
Works on a 4G data connection, so maybe a peering issue?...
Fingers crossed for a fix
Tracing route to www.ebay.co.uk [104.66.89.141] over a maximum of 20 hops
1 5ms 5ms 6ms 195.166.128.172
2 5ms 6ms 6ms 84.93.249.34
3 6ms 8ms 6ms 195.166.129.4
5 6ms 6ms 6ms 104.66.89.141
Trace complete.
Tracing route to mesg.ebay.co.uk [66.135.223.225] over a maximum of 20 hops
1 6ms 5ms 5ms 195.166.128.172
2 6ms 6ms 6ms 84.93.249.33
3 5ms 6ms 5ms 195.99.126.138
4 8ms 9ms 13ms 109.159.254.109
5 9ms 9ms 8ms 213.121.193.150
6 7ms 7ms 7ms 166.49.211.240
7 7ms 7ms 7ms 80.157.129.113
8 99ms 99ms 99ms 62.154.5.138
Trace complete.
29-02-2016 12:49 PM
I am going to ask on KITZ now.
29-02-2016 1:16 PM
http://downdetector.co.uk/problems/ebay/map/
Looks to be an ISP routing problem rather than an ebay problem, though.
29-02-2016 1:32 PM
29-02-2016 2:11 PM
Even Hermes classic site disappeared leaving just the mobile site version which I find appalling to use on a PC.
Thankfully that was only temporary as I find the mobile version so useless and so slow that it's quicker for me just to walk to the post office.
29-02-2016 2:13 PM
Ebay has been spiking my cpu with all browsers like crazy since I upgraded to Windows 10, unrelated but thought I swould see if anyone else has issue?
29-02-2016 5:09 PM
I VPN to france and it works fine, so that's a workaround if anyone needs it
29-02-2016 5:31 PM
Getting about as much response from ebay as this thread is getting from PN.
http://community.ebay.com/t5/Technical-Issues/Is-anyone-else-having-problems-with-their-Messages-pag...
And:
http://community.ebay.co.uk/t5/Seller-Central/Is-there-a-problem-with-messaging-on-ebay-as-keep-gett...
They are "closely monitoring".
29-02-2016 5:37 PM
29-02-2016 5:41 PM
29-02-2016 5:55 PM
This isn't something just affecting Plusnet customers:
http://www.ispreview.co.uk/index.php/2016/02/ebay-uk-problems-strike-bt-broadband-customers.html
Quote eBay UK Problems Strike BT and Sky Broadband Customers...
... However we’ve also seen customers of Virgin Media, EE Mobile and PlusNet reporting similar issues, which perhaps points the finger back towards eBay again...
