fibre unlimited - only 50% speed
basvw
Hello Plusnet
I signed up for Fibre Unlimited, however my line only gives me around 35-40Mbit download and 10Mbit upload speed. I have been waiting for a few weeks now to see if this gets adjusted automatically but unfortunately that's not the case.
Various different speed tests show the the speed at less than 40 Mbit. In the router menu the downstream is noted as 40.23 Mbps.
BT speedtest attached. Upstream showing as 3 Mbps of 20 Mbps possible..
Can someone from Plusnet please look into my line, as I am paying for a faster line?
basvw
Re: fibre unlimited - only 50% speed
Anyone from Plusnet please?
Fixes: 183
That speed is correct for your product - it's Unlimited Fibre Extra that is up to 80mbps Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
basvw
Re: fibre unlimited Extra - only 50% speed
Hi dvorak. Sorry, but this speed is definitely not correct for my product. My title was is not correct, product is fiber unlimited extra.
As you can see from the speedtest I don't even reach 40mbps down, and not more than 5mbps up (when I'm lucky). I should be reaching a lot more, the estimated minimum was 49mb and max 64mb, which is far from what I'm reaching. If this can't be helped I might as well "downgrade" to normal fibre unlimited with a max of 38mb..and pay less.
Fixes: 183
what did the email from PN give you for your speed estimate?
basvw
49mb to 64.4mb
Fixes: 183
as you're outside the estimates you could raise a fault.
it might be worth just double checking your estimate here first though https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
basvw
Thanks how do I raise a fault?
The btwholesale site says I'm on market B exchange, then I assume I look at vdsl B, which says max 54.8 and min 32.4.
Plusnet Staff
Plusnet Staff
Fixes: 116
Hello @basvw I'm sorry to hear you're having speed issues.
There appears to be two accounts linked to your forum details, please can you private message me with the username you're referring to?
Thanks.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
basvw
@Anoush send you a pm
Plusnet Staff
Plusnet Staff
Fixes: 116
Thank you for your PM @basvw
I've tested your broadband, your router is in sync at a low speed,
xDSL Status Summary
Circuit Sync Status
: In Sync
Downstream Line Rate
: 41.2
Upstream Line Rate
: 10.7
The line test is failing when running the broadband test,
GEA Details
Bridge Tap
: Not Detected
Radio Frequency Ingress
: Not Detected
Repetitive Electrical Impulse Noise
: Not Detected
Copper Line Test Result
: Voice fault suspected - contact Voice CP to progress copper issue
NTE Power Status
: PowerOn
Crosstalk
: Not Detected
I've however tested your line and I'm not identifying a fault.
I'd advise to try connecting your router into your test socket (if you haven't already, and if you have one). As explained here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If your speed isn't on target still, then you can raise a fault to us at http://faults.plus.net
 Plusnet Staff
basvw
thanks for the help. connected to the other socket I have here, which appears to be the master, because it shows 58mb downstream in this.  Although it's in an impossible location to use... so need to figure out how to move the master..
Plusnet Staff
Plusnet Staff
Fixes: 116
That's a pretty nice jump in speed. Is this your test socket or just through the faceplate of the master?
We'll be able to arrange for your master socket to be moved by Openreach, though the callout fee is pricey at £160.
You could also possibly look for a qualified electrician or ex-BT engineer elsewhere.
 Plusnet Staff
