Draytek 2850 - PPPoE - no response from server side
- Draytek 2850 - PPPoE - no response from server sid...
05-01-2018 11:12 AM
This VDSL router/modem combo has been working for years without problems.
This morning, it dropped the connection and after several reboots etc., it does keep throwing the error:”PPPoE: no response from server side”.
Nothing has been changed at this end.
See attached configuration screens for some of the VDSL settings.
Please help, this is important as I need my internet connection for work.
Thanks so much,
Wim
Thanks so much,
Wim
1 REPLY 1
Re: Draytek 2850 - PPPoE - no response from server side
05-01-2018 12:18 PM
Not sure what happened, but I ended up putting Display name to Plusnet, and enabled ADSL tag insertion (value 101), even though it’s never needed that as it’s VDSL tag and that was correctly set to 101 too.
I may try and eliminate & isolate to work out what did the trick and change things around. But it’s kind of a case of “don’t touch it!”
Hope this helps someone out in future.
Cheers,
Wim
Cheers,
Wim
