DLM on my line or?
- DLM on my line or?
Re: DLM on my line or?
08-04-2015 12:05 PM
Maybe I will get an apology from them that told me I was talking rubbish is due.....
I mean... c'mon.... the evidence against them isn't half piling up!
08-04-2015 6:44 PM
08-04-2015 6:46 PM
08-04-2015 6:48 PM
08-04-2015 7:13 PM
08-04-2015 8:47 PM
This site was my original point of reference and I think all the relevant info is there: https://huaweihg612hacking.wordpress.com (though you may need to scroll down a fair bit since I think lots has been added since I used it).
09-04-2015 7:46 AM
Quote from: darklight Not sure how, but i think i need to use the second port on the modem to my router am i right? i think the web interface may conflict with my asus router because it uses 192.168.1.1 same as the modem.
Sorry I forgot to reply last night.. did you manage to sort the modem OK?
I can give you step by step instructions to help you access the web gui of the HG612 and also change the HG612's IP address so that it is accessable off your network and not conflicting with you router!
Let me know
09-04-2015 8:28 AM
09-04-2015 9:04 AM
To access the HG612 Web GUI & Change the Lan IP address, you will need to do the following.
1. Configure your PC's LAN IP to 192.168.1.101 (Below is a picture of what your IP config should look like)
2. Connect your HG612 Modem to your PC using Lan 2 on the modem.
3. On your PC navigate to 192.168.1.1 using your preferred browser.
4. You should now see a login screen asking for a username and password, use admin for both Username & Password.
(If you don't see a login screen, be sure that you installed the "Web GUI" version of firmware and not just the unlocked version on your modem)
5.Once Logged in, Locate Basic in the side menu click this and then Click Lan in the sub menu.
(You should see the following)
6. Change the IP Address from 192.168.1.1 to 192.168.1.100 (Assure this IP is not in use on your network, If it is then choose an alternative that isn't, Eg. 192.168.1.200.) then click submit.
7. Now try navigating to the new IP address that you have just assigned your modem and you should see the login screen.
8. If this has been successful then you can now connect LAN 1 to your routers WAN and LAN 2 to your Routers LAN and all devices on your network should be able to navigate and access the modems Web GUI from the new modem IP: 192.168.1.100.
If you have any issues come back and I will do my best to assist.
09-04-2015 9:40 AM
09-04-2015 9:48 AM
09-04-2015 9:49 AM
IP Address: ***.***.***.***
Subnet Mask: ***.***.***.***
Default Gateway: ***.***.***.***
Default Gateway should be: 192.168.1.1
Subnet Mask Needs to be: 255.255.255.0
If you have already configured your LAN manually from your current network then, yes its possible everything could work fine.
09-04-2015 11:38 AM
oh another thing won't my router lose connection to the modem if i change the ip in the modem.
09-04-2015 11:41 AM
09-04-2015 11:59 AM
