another quick speed question
- another quick speed question
10-04-2015 9:40 AM
Since then over wifi BT speed test shows 23mbs maximum I've been able to achieve (attached)
Question is am I being impatient, will this improve dramatically?
Should I raise a ticket?
I've read about rebooting the router every morning for a the first 2 or 3 is this correct?
many thanks in advance
Re: another quick speed question
10-04-2015 9:51 AM
Can you check wired if you haven't
10-04-2015 9:56 AM
Quote from: Oldjim Unless this is very low https://portal.plus.net/my.html?action=data_transfer_speed or you are testing via wireless then something is adrift
from the attachment looks like i should expect 57mbs?
Using wired same speed unfortunately
10-04-2015 10:07 AM
The bit you need is the current line speed and that is 78Mbps
So there is a problem
Before raising a fault I suggest letting the staff on here take a look
10-04-2015 10:08 AM
jim:quote
10-04-2015 11:21 AM
10-04-2015 11:36 AM
10-04-2015 12:07 PM
10-04-2015 12:22 PM
10-04-2015 1:00 PM
