DLM/Profile Check
- DLM/Profile Check
DLM/Profile Check
16-11-2020 2:58 PM
Any chance someone would be able to check what IP profile I'm on please? I have a static IP therefore don't get the DLM resets. Router line speed is 71Mbps and my sync is 68Mbps but my download speed isn't matching this...
Cheers
Re: DLM/Profile Check
17-11-2020 2:30 PM
17-11-2020 2:53 PM
Hi @wratten85, thanks for getting in touch and I'm sorry to hear you're having speed issues as of recent. I can't see anything out of place with your account profile. Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
17-11-2020 3:03 PM
Thanks for the reply! Any chance you could let me know what profile I'm currently on? The BT wholesale speedchecker came back saying I was on 62Mbps
Cheers
18-11-2020 8:27 AM
20-11-2020 2:37 PM
20-11-2020 3:12 PM
Hey there @wratten85,
Apologies for the delay in response. From checking over the GEA test ran today you are on the correct profile for your line, as my colleague mentioned if you're seeing low speeds please raise a fault via that ticket and we can go from there.
Thanks.
