DGND3700v2 is now ready for VDSL2 - BUT only via the BT Modem
- DGND3700v2 is now ready for VDSL2 - BUT only via t...
- « Previous
- 1
- 2
- Next »
Re: DGND3700v2 is now ready for VDSL2
01-02-2015 4:31 PM
Oldjim - I do apology as I have tested again as the DGND3700v2 only will work with FTTC on the WAN port with Openreach Modem because the v2 doesn't have VDSL2 inbuilt modem. Only the v1 does have VDSL2 inbuilt modem.
I try to correct the first post but it won't let me re-edit. I do apology for the mix up confused.
DGND3700 v1 will work with FTTC (with or without Openreach Modem) (both work with DSL and WAN ports)
DGND3700 v2 will not work with FTTC (without Openreach Modem) (won't work with DSL port)
DGND3700 v2 will work with FTTC (with Openreach Modem via WAN port)
As I have tested both v1 and v2.
Message 16 of 21
(3,465 Views)
Re: DGND3700v2 is now ready for VDSL2 - BUT only via the BT Modem
01-02-2015 4:57 PM
Opening post and title corrected
Message 17 of 21
(3,465 Views)
01-02-2015 5:01 PM
Thanks Oldjim.
Message 18 of 21
(3,465 Views)
01-02-2015 7:49 PM
Don't worry Max I understood what you meant
Downside is the v1 only supports the older 35m.bin
Have you taken a look at firebricks for aaisp ?
Message 19 of 21
(3,465 Views)
02-02-2015 9:56 AM
Quote from: goldenfibre
Is this with official firmware?
Message 20 of 21
(3,465 Views)
02-02-2015 10:28 AM
Message 21 of 21
(3,465 Views)
- « Previous
- 1
- 2
- Next »
