Speed dropping
Moblies
Speed dropping
Any work going on, my fibre has been dropping and varying speed for the last few days.  Had huge pings.
Roadie
Re: Speed dropping
Same for me, speed and pings all over the place, no two speed tests the same.
goldenfibre
Fixes: 6
Re: Speed dropping
Try hop onto different gateway see if it has improvement?
Fixes: 236
Re: Speed dropping
Hi there.
Our tests aren't showing any issues with your connection.
Is this over a wired or wireless connection?
 Matthew Wheeler
