Connection keeps on dropping -- Can't resolve https://dbtpnhdm.bt.mo
- Re: Connection keeps on dropping -- Can't resolve ...
16-04-2020 9:58 AM
Hello Plusnet
Overnight, our broadband connection has started to drop connections.
Was working fine last night - this morning it's been unable to maintain a consistent connection.
Seeing numerous errors in the router logs of the following nature:
08:11:09, 16 Apr. | ( 4948.490000) CWMP: session closed due to error: Could not resolve host |
08:11:06, 16 Apr. | ( 4945.810000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
Call centre is not accepting any calls at this time -- connectivity has been intermittent this morning - please assist - i need this connection to WFH.
Re: Connection keeps on dropping -- Can't resolve https://dbtpnhdm.bt.mo
16-04-2020 1:12 PM
Hi @Allfankledup,
I'm sorry that your connection is dropping and for the inconvenience that this is causing you. I've attempted to test the line but the test isn't running correctly at the moment and indicates that this may be because the landline is currently in use. Please can you confirm whether you're currently on the landline? If not, I will try and run the test again.
16-04-2020 2:29 PM
Hey @EmilyD - thanks for getting back to me - Line is currently free if you want to run your test again.
I powered down the router for 20mins this morning and it's been ok since - but I'd like to ensure that it's going to stay working..
thanks
16-04-2020 3:15 PM - edited 16-04-2020 3:16 PM
Thank you for confirming that. Things do seem to have stabilised since you powered the router off this morning, with the connection log showing no drops over the past five and a half hours. Testing your line isn't picking up any problems from here at the moment:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 42.1 Mbps | ||||
Upstream Speed | 13.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 782.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Good | ||||
Interference Pattern | Regular Interference Observed on Week Days | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From03:45to04:00 | ||||
Interference Location | Unknown | ||||
Interference Observed In Days | 3 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Retransmission Low | ||||
Time Stamp | 2020-04-03T15:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 43.2 Mbps | 45.3 Mbps | 44.7 Mbps |
Up Stream Line Rate | 12.9 Mbps | 13.4 Mbps | 13.0 Mbps |
Up Time | 121.0 Sec | 900.0 Sec | 896.4 Sec |
Retrains | 0.0 | 6.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-04-16T13:44:05Z | 2020-04-16T13:59:05Z |
Ingress Code Violation | 2 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I'd recommend that you keep an eye on your connection and if it starts dropping again run through our troubleshooting guide here. Please get back in touch if the troubleshooting doesn't resolve the problem.
