Can someone check my stats please
bigal993
Hi Guyz
 have been with plusnet for over 8 years, and had a steady 40mb download speed, from day one.
I use the BT wholesale speedtest regularly.
During the last two weeks we have had about 12 power cuts from our electricity supplier.
Which has caused my ip profile to drop from 39mb to 30.8mb
I have just done a test on speedtest.net as well which confirms the drop from about 39mb to 28mb
https://www.speedtest.net/result/8047237314
Which is a huge drop, I understand that the system sees my connection as unstable due to all the disconnections, but the power outages have been fixed now, can someone please request a DLM reset,
 IP Profile for your line is - 39.68 Mbps taken on the 4th January 2019
 IP Profile for your line is - 30.08 Mbps that one is taken today
thanks for any help
Al
13 REPLIES 13
Fixes: 1,602
Re: Can someone check my stats please
Hey Al.
I've arranged for your line to be reset, I'd allow 2-3 working days for this to go through.
Let us know how your speeds look towards the end of the week.
Fixes: 1,602
As an update we've checked a back end system and it looks like your profile is 80/20 so a DLM reset isn't needed anymore. Your sync rate is also at 39.6mbps which is within your speed estimates of between 25.7mbps to 40.5mbps.
bigal993
Hi Gandalf,
many thanks for having a look at this for me,
Can I ask any idea why the Ip profile on my line has been reduced ?
is this due to the power outages ?
will it go back u again, as my net speed has fallen by 10mb, from 39 to 29,
Al
Fixes: 1,602
Hi Al.
The IP profile of the line should sit just beneath the sync rate but from what you've said it looks like it hasn't yet increased following your sync rate increasing and banding being removed. Unfortunately we don't have any influence over this so we may just have to wait for the DLM to make the change.
It may be worth rebooting your router to force a re-sync which may sort this out.
Let us know how it goes.
bigal993
Hi mate
thank you for all you did and the advice, a reboot worked tonight back up to to what it was before
thanks again
Al
bigal993
Hi Gandalf
i have been away on holiday for 3 weeks, came back to an internet speed of 7mb, down from 38mb, i rebooted my router its back up to 22mb but a ping of 84ms,
i tried to run a further diagnostic check on the bt checker, but it came back with this, is it possible to check my line for me please mate
Al
FAQ
null
The Performance Tester is disabled to support TAP3 for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
SammyM
Fixes: 98
Hello @bigal993,
I am sorry to hear that your speed has dropped, looking at our side the speed is spot on. I have inputted a GEA test below.
Can you advise if the speed test run was without any device connected via WiFi? Is the speed the same while in the test socket? If this is the case please can you raise a fault here.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 39.0 Mbps
Upstream Speed 7.2 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Estimated Line Length In Metres 974.2
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-03-14T21:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 42.1 Mbps 42.1 Mbps 42.1 Mbps
Up Stream Line Rate 7.1 Mbps 7.1 Mbps 7.1 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-03-27T20:38:30Z 2019-03-27T20:53:30Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Sammy M - Sheffield Team
bigal993
Hi Guyz My connection has been up and down again today, it was running at 20mb ealrier its got better as you can see by the check ive run, but still not as fast as it should be Any ideas ? Al
BD
Fixes: 86
Hi @bigal993, I'm sorry to hear you've been having connection issues. Checking form this side we can see there was 1 drop in connection around 14:45 today however the connection looks to have been solid for 30 days prior to that. When testing your connection we are seeing 37.6Mbps download getting to the router with no signs of a fault or errors. It may have just been a blip or a wider spread issue that has already been addressed and I'd suggest to monitor the connection and speeds from here to see if problems persist with the speeds dropping around the 20Mbps mark. If the speed issues do look to return and you haven't already, I'd advise running a wired speed test to rule out any wireless issues being behind the loss of speed and if you see the speeds much lower than expected let us know so we can investigate further. The estimates we have for your line are 25-40Mbps and although you may have seen speeds slightly higher than the current 37.6Mbps it may be that this increases over the next few days if the earlier speeds were a result as a wider spread issue.
bigal993
Hi Guyz
its back down to about 23mb download speed, i uploaded a screenshot of the BT wholesale test earlier, BT have upgraded a bit of kit, and my line now says its 40-45mb ? ben was saying its set to 30-40mb ?
can this be looked at please
thanks
Al
Fixes: 1,602
Hi Al.
I can see you're still provisioned on the 80/20 product and your line in sync at 37.6mbps.
Can you advise whether you're seeing the slower speeds on wireless devices or if they're wired to the router? If you're having issues over WiFi I'd give the steps Here a go to try to improve your wireless signal.
If your computer/laptop is already wired to your router do you have another device you can try to compare?
bigal993
Hi Gandalf,
Im on my Imac its wired directly to the router, the line has been fine for years, but started playing up a while ago, ive spoke to a guy at BT I know, he said they have upgraded my exchange, and my line sync speed is set at min  40 - 45 mb now with them
please see attached file below
Al
Fixes: 1,602
Thanks for getting back to us Al.
It's odd to see the IP profile so high on the BT speedtest however your line is definitely showing as in sync at 37.6mbps.
Either way I'm not sure that there's much we can do as we can't change any of these settings from our side for a fibre connection.
It may be worth arranging an engineer to investigate this further by raising a fault Here letting us know when you've completed it however it's likely that the end result of an engineering investigation may be that your line is performing within expectations and a call out charge may be applicable which ideally we don't want to see.
I've attached your test results below:
GEA Test Detail
Circuit ID: N/A Service ID: [redacted]
Test Outcome Pass
Sync Status In Sync
Downstream Speed 37.6 Mbps
Upstream Speed 7.1 Mbps
Estimated Line Length In Metres 988.5
Technology VDSL
Time Stamp 2019-05-15T20:45:00
Down Stream Line Rate 39.4 Mbps 41.2 Mbps 41.2 Mbps
Up Stream Line Rate 7.0 Mbps 7.1 Mbps 7.1 Mbps
Up Time 865.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Start Time Stamp 2019-05-28T19:14:44Z 2019-05-28T19:29:44Z
Errored Seconds 0 0
