Broadband connection problem
- Broadband connection problem
09-06-2020 11:44 PM
Re: Broadband connection problem
10-06-2020 7:53 AM - edited 10-06-2020 7:54 AM
@Adam78 sounds like your account hadn't activated. If its still not working today, the I would suggest giving support a call
10-06-2020 10:01 AM
@MisterW is most likely correct but just in case are you aware that you must drop the DSL line by either using the disconnect tab in the hub settings or remove the DSL cable before changing the username and password? Obviously you then need to reconnect after changing the settings.
10-06-2020 10:17 AM
