Any capacity issues?
- Any capacity issues?
Re: Any capacity issues?
13-01-2015 10:39 PM
http://aastatus.net/2069
13-01-2015 10:53 PM
13-01-2015 10:58 PM
13-01-2015 10:59 PM
13-01-2015 11:14 PM
On the bad SVLAN/gateway its congested well into dusk hours as well.
Plusnet really need to open their mouths here and provide some proper information, it cannot be that hard to get hold off.
14-01-2015 1:44 AM
Quote from: chrcoluk Melancholie am I right that if I hop I can move between different SVLAN's?
No. The mapping is static and not session-dependent.
14-01-2015 1:51 AM
14-01-2015 2:39 AM
14-01-2015 4:00 AM
Quote from: Melancholie
ok thanks for info, I will test over next few nights but it would seem based on my testing so far the SVLAN might not be the issue for me.
Fingers crossed for you that aaisp have got what is your issue and it gets resolved soon.
14-01-2015 4:08 AM
14-01-2015 10:03 AM
14-01-2015 10:51 AM
14-01-2015 2:26 PM
Done about 7 speedtests one after the other.
IPv6
First was almost good but on the x1 test had a dip.
Second was ok on down speeds but upload was struggling to go above 6mbit/sec
Third and Fourth same which I aborted as very long wait for upload to finished.
Then I forced browser to IPv4
Upload fixed but for 2 tests one after the other x1 was around 30mbit/sec wavy
Then next test was fine.
What I want to know given when on pro I only had light congestion for small parts of the evening yet back on a non pro account its much worse, do any plusnet endpoints have saturation for any part of the day? if not are any of these red/amber SVLAN's confirmed for my connection?
14-01-2015 3:26 PM
14-01-2015 3:37 PM
I am sure their network is a bit heavy, they've been busy balancing load which you don't do for fun, however the impact of this would be pretty widespread.
