website worry
gardent
website worry
Below is a condensed version of our recent ticket at Greenby 'support'. Since the bot handed us over to an agent we have heard absolutely nothing! Even the bot won't talk to us anymore when I try and query any progress.
Is it true that all migrations are complete or is the bot generalising? This probably isn't Plusnet's problem, but If Greenby won't talk to us how do we get the website back online? (and why isn't it on our greenby dashboard anyway?)
"Our website has disappeared! (www.[our accountname here].force9.co.uk)
Is it being transferred from Plusnet to Greenby at long last? -the emails have been at Greenby for ages. There is no mention of it on our Greenby portal yet.
I only checked something on it a couple of days ago. When will it be back online?"
"Sorry to hear your website isn't loading. Our records show this was a known issue with Force9 webspace that has now been fixed, so please try again now."
"Your migration is also complete. All migrations for all ISPs have finished, so your account and webspace are no longer with Plusnet. If your Greenby portal doesn't show the webspace or domain details yet, the website should still be reachable at the address above."
"No, it still doesn't work. I get "Not Found. The requested URL was not found on this server.""
"I'm sorry the site is still not loading. Since the fix hasn't worked, I'll need to pass this to an agent who can check the webspace on your account. Before I do, please reply with the email address on your Greenby account so they can find it."
"I'm transferring you to an agent now, they will be with you shortly."
"We're sorry for the delay. Your ticket is in the queue and will be answered as soon as possible. This request has been logged, and if you prefer not to wait, we'll follow up by email."
Artificial Intelligence Bot
20/11/2026 13:32:30
3 REPLIES 3
plusnettony
Fixes: 80
Re: website worry
Can you log into your FTP ? If so, are there any files in the htdocs directory?
 Tony T
gardent
Re: website worry
Unfortunately, the last time I personally changed any files I was using the ftp function in Windows explorer on XP! It was probably accessible through the Plusnet/force9 site as well wasn't it. I have basically forgotten how to do it and I don't know where to start on Win10. If someone can point me at a quick aide memoire it would be appreciated.
plusnettony
Fixes: 80
Re: website worry
It's been a while since I did this, but if you don't have FTP software, try ftp://ftp.plus.net in either Edge or Windows Explorer.
You're better option would be a client such as WinSCP, where you enter your host name (ftp.plus.net, username and password) and connect. Then check the htdocs directory. I'm fairly sure we don't have a copy of your site on our servers any longer, so I'm hoping it's a config issue on Greenby's end.
 Tony T
