stuck with ftp
- Everything else
- stuck with ftp
stuck with ftp
05-06-2011 5:30 PM
Thanks if anyone can help.
Re: stuck with ftp
05-06-2011 5:41 PM
Customer and Forum Moderator. Windows 10 Firefox 87.0 (64-bit)
Re: stuck with ftp
05-06-2011 6:57 PM
Re: stuck with ftp
05-06-2011 8:09 PM
Ken
Re: stuck with ftp
08-06-2011 2:48 AM
Re: stuck with ftp
08-06-2011 11:58 AM
Re: stuck with ftp
08-06-2011 6:25 PM
dick:quote
Re: stuck with ftp
08-06-2011 6:47 PM
Re: stuck with ftp
08-06-2011 7:46 PM
I'll try a stand-alone programme. Preferably one that is idiot proof!
These things probably all seem very simple to the average forum member but I seem to be slow. (I've got another issue with my daughter's laptop failing to log on to my network despite my best efforts... Must be something to do with those WEP codes, I guess). If only life was a simple as in the dawn of time when a 'calculator' was about the size of my desktop tower!!
Re: stuck with ftp
08-06-2011 8:02 PM
E.g. http://www.kennethnoble.co.uk/htdocs/temp/moths/micro9.jpg just returns a 404 error. So perhaps the problem is nothing to do with the ftp programme at all. (I can see the home page OK at http://www.kennethnoble.co.uk/ ; )
Re: stuck with ftp
08-06-2011 9:41 PM
Re: stuck with ftp
08-06-2011 10:05 PM
When you upload to the htdocs folder; you're telling the webserver that you want that content to be visible to the public, I believe htdocs is an abbreviation for http documents (could be wrong there).
When you're trying to find the files that you've uploaded to the folder, you don't need to include /htdocs/ in the external url; which is why it wasn't finding the file. The htdocs folder when youre viewing it in ftp essentially is "www.kennethnoble.co.uk". Geeks like myself refer to this as the "Root Directory".
So... if you remove the /htdocs/ from the url below... http://www.kennethnoble.co.uk/temp/moths/micro%209.jpg
tada 😃
Hope I explained that in a way that makes sense! If not just let me know and I'll try and reword it so it does!
Also just a little word of advice; some web browsers don't like spaces in web file names, so its usually best to get rid of any gaps before uploading.
Good luck!
Re: stuck with ftp
08-06-2011 10:57 PM
That %20 is the URL encoded value for a space; the filename of the photograph is "micro 9.jpg", ie it includes a space. Avoiding these is sound advice. Also be careful with case, Windows ignores case, Linux (the operating system on the web server) does not.
Re: stuck with ftp
09-06-2011 8:16 PM
