rDNS change
TechRC
rDNS change
Hope you're all well.
Recently bought a Static IP. I need the rDNS changed to anything other than my PlusNet PPPoE/account name.
Thanks!
2 REPLIES 2
Fixes: 480
Re: rDNS change
Moderator's note:
Thread moved from Tech Help to Everything Else
willcutforth
Fixes: 113
Re: rDNS change
@TechRC you can have it as static IP, domain name so long as the A record points to the static or the username. You choose which one you want and let me know.
 Will Cutforth
