rDNS change required
FIXEDTopic Options
- Everything else
- Re: rDNS change required
10-10-2023 9:53 AM
Hi, can someone action an rDNS update for me please, changing the record from my username to just the IP address?
Thanks in advance
James
Fixed! Go to the fix.
Message 1 of 3
(1,087 Views)
2 REPLIES 2
10-10-2023 12:22 PM
Hey there @stagetechuk I can sort this for you but I just need your username.
I will PM you for this now.
Message 2 of 3
(1,072 Views)
10-10-2023 12:29 PM
Thanks for sending that over James ![]()
I have raised a ticket on https://www.plus.net/wizard/?p=view_question&id=237486515
If you reply to that I can get it sorted
Message 3 of 3
(1,068 Views)
- Everything else
