ccgi re-direct: DNS records entry?
- Everything else
- Re: ccgi re-direct: DNS records entry?
24-08-2007 2:19 PM
Hello
PlusNet has a bit of troubles to re-direct my new domain to ccgi. This is ongoing for the last couple of days.
Here I would like to just ask and check if these are the correct settings in the domain control tool:
Additional DNS records (Advanced)
Left field Type Pri Right field
domain.org.uk. a 84.92.1.4
mx 20 mx.last.plus.net.
www cname ccgi.plus.net.
I have several times checked, but these settings are exactly as the ones for my primary domain (except the domain name of course).
So, I don't know why my new domain points to the main PlusNet page http://www.plus.com , but it seems it is down to PlusNet's technicians.
Nice day to all
Nice day to all
Message 1 of 7
(4,406 Views)
6 REPLIES 6
24-08-2007 2:30 PM
This could actually be attributed to this problem
You can find the domain records required to point it to the cgi platform at this link
Message 2 of 7
(1,275 Views)
24-08-2007 3:17 PM
Hello
Thank you for the reply and for pointing to the status of a current network problem.
The tutorial is known to me, but it does not discuss what to do for to point to ccgi the http://domain.tld and the http://www.domain.tld (the first one without www, the second one with www). There had been a thread on the old forum where I had got the settings above, which work with my main domain. So I wanted to double-check if that also applies for a second domain.
The tutorial is confusing in regards to subdomains, as these do not work on PlusNet. Otherwise I would already have a http://forum.domain.tld switched through.
Possibly someone would update the tutorial.
Nice day
Nice day
Message 3 of 7
(1,275 Views)
24-08-2007 10:23 PM
My domain is still not connected to ccgi.
Do I need to set PRI for the second domain to another number, e.g. to 25 instead of 20? - or does this not matter?
Second question:
does anyone know what the IP-address of my ccgi.space is, or does such thing not exist?
Self-answer: No, there is only the PlusNet IP
See this from iptools.com:
Non-authoritative answer:ccgi.username.plus.com
canonical name = ccgi.plus.net.
Address: 84.92.1.4
So, that seems to be the proof that PlusNet then internally directs to the user's ccgi. Hope, that PN will get this soon done.
Second question:
Address: 84.92.1.4
Message 4 of 7
(1,275 Views)
28-08-2007 9:27 PM
Is it accepted practice that an ISP (in this case PlusNet) is technical not able to point a new domain within a week to ccgi?
Ticket ID: 22639097. I contacted several times customer services, to no avail.
What do other people think about that?
Message 5 of 7
(1,275 Views)
28-08-2007 10:15 PM
Found that somebody changed the entries of my first domain to:
And it still works.
Okey, so I did this now with the new one as well - hope it helps.
Left field | Type | Pri | Right field |
domain.tld. | a | 84.92.1.4 | |
www | a | 84.92.1.4 | |
mx | 20 | mx.last.plus.net. |
And it still works.
Message 6 of 7
(1,275 Views)
31-08-2007 5:06 PM
Long wait. Finally PlusNet directed my domain away from their plus.com-page to my ccgi-webspace. Seems to be like in Japan where whole companies close down for a week, otherwise the employees wont go in annual leave?
Message 7 of 7
(1,275 Views)
- Everything else
