Windows 10 reset
Re: Windows 10 reset
If Thunderbird on Windows is anything like the Linux version, then you will need to "Show Hidden Files" or equivalent to be able to search for the Thunderbird data folder.
I'm unable to check and say exactly how you would do that - I also migrated to Tux many years ago!
Fixes: 251
In file explorer look at the options under VIEW.
Good call - as I’ve always got that set I don’t remember!!
RobPN
Fixes: 15
Likewise @Townman, good call @Anonymous, something I never think about either!
Edit:  @BB - abbreviations can always be Googled Wink
BB
Hi, I managed to get my address book back. But no way to find my previous email folders.
RobPN
Fixes: 15
@BB
So did you find the old profile file, which would contain your address book along with everything else, subject to what @MisterW said about POP vs IMAP early in the thread?
Have you got 'Show Hidden Files' set as referred to (by @Anonymous and @Townman ) above?
Edit: punctuation
RobPN
Fixes: 15
@BB
You could try running Thunderbird using the 'P' switch.
Press the 'Windows' and 'R' keys, then enter thunderbird -p and click OK.
If more than 1 profile is offered you can make a choice.
