Wi fi calling
pvmb
Champion
Fixes: 17
Re: Wi fi calling
Weird!
Same as the OP here. Tesco Mobile, I always use Wi-Fi calling when at home on my Tesco Mobile smartphone. This morning (possibly unnoticed last night) Wi-Fi calling is simply nor working. No Wi-Fi calling icon shown in phone's status area. Tried turning it on an off, rebooting phone, rebooting Hub 2 router. No joy.
Just got off Chat with Tesco Mobile Support and was told phone mast down in my area (but can still make actual 4G phone calls!). Not an unfamiliar occurrence in my experience 🙄. Over the years, with my previous 2G phone, it's been up an down more times than I like to remember.  Men up ladders, platforms up mast, pulleys up mast, aerial riggers up mast... Mind you, that was 2G, possibly a different mast this time, who knows?
But it didn't occur to me to look into status of local base stations* - though I did ask Chat agent if an issue with O2 network.
So, does anyone know how Wi-Fi calling actually works? I assumed once it disappeared into the router it was then picked up onto the relevant network by some data equipment in an O2 building somewhere. Never occurred to me that it was retransmitted locally over phone networks. Or is the 'data equipment' in a local base station cabinet? But then, why is it 'local' at all?
Mystified.
* Just checked...
! Looks like a nearby phone mast isn’t working as it should, sorry.
Our engineers will be on the case already, and your service might come and go until we fix it. Just so you know, from Monday 18 January 2027 we’ll also be carrying out work with the aim to improve our network service in this area. We’re sorry if your service is affected while we work – we’ll do our best to minimise any impact. Updated 09:37 (refreshed hourly). Recent faults might not show yet.
pvmb
Champion
Fixes: 17
Re: Wi fi calling
Wi-Fi Calling is back!
I must say, that seems uncharacteristically quick for these O2 issues.
Fixes: 585
Re: Wi fi calling
Wifi calling works by making a VPN connection, over whatever broadband you have, to your mobile network data centre (wherever that may be). Your calls are then routed over that VPN connection.
pvmb
Champion
Fixes: 17
Re: Wi fi calling
@MisterW
"Wifi calling works by making a VPN connection, over whatever broadband you have, to your mobile network data centre..."
That's what I thought! (More or less). So why would local phone mast/base station issues affect it?
Fixes: 585
Re: Wi fi calling
It wouldn't! You were just being fed 'bovine excrement' by the support agent!
pvmb
Champion
Fixes: 17
Re: Wi fi calling
@MisterW
OK. And yet there IS a local phone mast/base station issue.
Maybe not directly the cause, but associated network engineering issues/work?
Fixes: 585
Re: Wi fi calling
If you don't have the phone set to 'prefer wifi calling' , then it will still attempt to use the mobile network. If there's good signal strength but a call routing fault then that could be an issue.
pvmb
Champion
Fixes: 17
Re: Wi fi calling
@MisterW
Nope! When at home I switch on 'Aeroplane mode'. Hence no mobile phone network service. I first noticed the issue precisely because phone said calls/texts not going through and asking to switch off 'Aeroplane mode' so that it would work.
Fixes: 585
Re: Wi fi calling
In that case , the local mast can not have any effect on wifi calling. They obviously had another problem in the network somewhere.
pvmb
Champion
Fixes: 17
Re: Wi fi calling
It's gone again!
This is most frustrating. I have been using Wi-Fi calling for nearly a year now and until the last days it has been an unfailing presence - when at home I effectively use it as a replacement for my old DECT landline phone. Now it's up and down like a Yo-yo. Will it ever come back? What is happening?
What can you do about it? There seems nobody takes responsibility for it. If it were the main mobile phone signal you could complain to the provider (Tesco) or the underlying phone company (O2), you could look up its status. With Wi-Fi calling all you get is to read guff about "Have you got a 4G phone?", "How to turn on Wi-Fi Calling" etc.
Could it be an IP issue? There are rumours online, I have checked mine out and can see no bans. But who knows.
Just quickly checked on phone. It's come back again! 🙄
Ian06
Fixes: 6
Re: Wi fi calling
I think I have lost WiFi calling too...  normally my iPhone 15 says WiFi-Calling on the top banner... it now says Lebara.
Just check on OH's iphone and she has WiFi Calling on hers...  not sure what's going on.
We have Plusnet Full Fibre here at home and are both on Lebara (Vodaphone) her iPhone is older than mine (could be a iPhone12.)
I disconnected the Router/ONT a couple of times this week while doing some work, so may have changed IP address - I did a quick check and the IP looks ok on "what's my IP", is in London and doesn't seem to be blacklisted.  My phone seemed to be correctly connected to WiFi calling earlier in the week when I first saw this post.
It's not such a big problem as I can get a Lebara(Vodaphone) signal here at home, but it's a bit hit and miss and so I'm a little concerned as we ditched the landline a few years ago when we went to Full Fibre.
Ian06
Fixes: 6
Re: Wi fi calling
and it seems to be back again now -- what is going on...?
pvmb
Champion
Fixes: 17
Re: Wi fi calling
@Ian06
"and it seems to be back again now -- what is going on...?"
What is going on, indeed? Now you see it, now you don't! Currently, for me, it is back on again.
Someone, somewhere, has definitely been fiddling around in the innards at Tesco Towers. This morning (I think it was off in the morning) I received a text message from Tesco Mobile:
"On Pay as you go Essentials", you will now benefit from faster, more reliable connectivity with 4G Calling (also known as VoLTE). For more information visit <https link>
The link led to a document download: "Switching_off_3G_network_FAQs.pdf"
What? This was last year's news, surely?
Whatever they are doing, the sooner they stop doing it the better.
pvmb
Champion
Fixes: 17
Re: Wi fi calling
...Just seems to have come on again, after being off all morning (and earlier?) until just now. This seems to be a pattern now. WHAT is it all about?
pvmb
Champion
Fixes: 17
Re: Wi fi calling
Still have local network issues - though 4G phone network still seemingly working...
Check coverage and network status
https://status.o2.co.uk/
- How do I get a network connection when I don't have any signal?
When you have no signal, you can use Wifi to call and message instead.
If it's available with your device, you can use our Wifi Calling service to make calls, receive calls and send and receive text messages when you have no signal. We also have over 16,000 O2 Wifi hotspots available to connect to for free, which offer speeds up to 10 times faster than a normal mobile connection.
https://www.o2.co.uk/connectivity/wifi-and-4g-calling
 Uh-oh
Looks like something went wrong.
Try typing in the web address again, or head to our homepage or shop.
Um...
