Webstats not generated (6th April)
- Everything else
- Webstats not generated (6th April)
06-04-2013 9:31 AM
Can someone give then a kick again.
Tony
Re: Webstats not generated (6th April)
06-04-2013 9:39 AM
Keith
06-04-2013 9:40 AM
06-04-2013 12:11 PM
Quote from: chrispurvey We do now have in-place a more vigilant monitoring process for when/if this occurs.
That statement was made about 24 hours ago, after yesterday's webstats failure. No sign of a Service Status announcement yet.
06-04-2013 12:29 PM
Really sorry about this, especially two days running. We're looking into it now, I'll post a service status shortly.
06-04-2013 12:52 PM
We'll make sure we check into why it's failed two days in a row now, and get that sorted. Really sorry about this guys.
06-04-2013 12:52 PM
David
06-04-2013 7:30 PM
Actually, looking at the service status it says the next update is due '08/04/2013 @ 11:00', so that it it for the weekend.
Tony
06-04-2013 9:57 PM
Quote from: Tony Actually, looking at the service status it says the next update is due '08/04/2013 @ 11:00', so that it it for the weekend.
... just seen your post, with some degree of dismay. I'd seen the thread earlier, but hadn't added to it as it looked as though everything was in hand.
Quote from: kdiment If this script fails for the same reason each time it fails then it should have been fixed long ago. If it fails for a different reason each time then it must be very fragile and needs to be made more robust. Surely a job that has run every night for many years ought by now to have evolved into something more reliable.
... yeah : ) you're probably right.
Have to admit to being a bit concerned at the prospect of losing two days' worth of stats (primarily because it skews the monthly and annual cumulative figures).
More worried though that there's been a significant failure again, hot on the heels of the one a few weeks back where two consecutive runs failed and stats were lost. I read the update (other thread, yesterday I think) but I don't think it actually said what *caused* the failure on that occasion. And now a fairly swift recurrence, seemingly.
Whatever it is, I hope it's sort-able.
Regards,
Penny.
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
06-04-2013 11:54 PM
07-04-2013 9:07 AM
07-04-2013 11:04 AM
Quote from: Matt We're looking into it now, I'll post a service status shortly.
Quote from: Matt had a chat with Kelly and called the networks on call, we're trying to get them run for today so the stats aren't lost.
Did it really take 11 hours to decide to call someone to try to fix the problem?
Today's log file was generated about 2 hours earlier than normal and only contains the data for yesterday (6 April).
All of the data for 5 April has been lost despite Plus Net knowing about the problem since at least 12:29 yesterday.
07-04-2013 11:29 AM
From my conversations last night I'm aware of the procedural reason why action was not taken earlier (when the problem was raised). That is something that will need sorting out on Monday. Unfortunately the lack of feedback did not help to get those procedures challenged until it was too late.
David
07-04-2013 12:14 PM
08-04-2013 5:06 PM
We've flagged this up to the relevant team.
Sorry for any inconvenience caused.
Chris
- Everything else
