Web space
- Everything else
- Web space
Web space
28-10-2014 6:46 PM
Freenetname then morphed into MadasaFish and subsequently to Pus Net
I am trying to amend details on my web page but unfortunately cannot do so
Any suggestion / help gratefully received
Regards
Re: Web space
29-10-2014 9:52 AM
The FTP server address you need is www.users.freenetname.co.uk
Your username is the same as the one you use to log into the Madasafish website (minus the '@freenetname.co.uk' bit).
Your password is your regular Freenetname account password.
I've checked things from this side and those details seem to be working:
~$ ftp www.users.freenetname.co.uk
Connected to www.users.freenetname.co.uk.
220 ProFTPD Server [freenetname.co.uk]
Name (www.users.freenetname.co.uk:bpullen): [REDACTED]
331 Password required for [REDACTED]
Password: [REDACTED]
230 User [REDACTED] logged in
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> ls
200 PORT command successful
150 Opening ASCII mode data connection for file list
drwxrwxr-x 2 ftp ftp 4096 Oct 28 17:10 Index_files
-rw-rw-r-- 1 ftp ftp 4998 Oct 28 17:10 Index.htm
drwxrwxr-x 7 ftp ftp 4096 Oct 28 17:10 Page 1
drwxrwxr-x 7 ftp ftp 4096 Oct 28 17:10 Page 2
drwxrwxr-x 2 ftp ftp 4096 Oct 28 17:21 public.html
226 Transfer complete
Re: Web space
29-10-2014 12:20 PM
Many thanks for your help
I have now successfully uploaded to the site (transfers complete) but am unable to access it as it says site not in use?
Any suggestions please
Re: Web space
29-10-2014 1:10 PM
This points at the 'public_html' folder on your webspace (which you don't seem to have). I've created that folder now and placed a test file in there which you should be able to browse to.
Hopefully you can work things out from there?
* Edit: Alternatively you can also use your .co.uk domain without the trailing slash/username etc.
Re: Web space
29-10-2014 3:50 PM
Many thanks once again
Copying and pasting from your post, using my user name, I get "This web site belongs to a customer of Madasafish and is currently not in use. If you are the owner of this siteand you would like help on how to load information ..."
Using my domain name http://www.austerfield.org.uk doesn't produce anything
Regards
Re: Web space
29-10-2014 4:49 PM
If I browse to your domain name, I see the attached (which is the file I put there).
Same applies browsing to the ~username variant.
Re: Web space
29-10-2014 5:20 PM
Here is a snip of my screen showing details of the FTP server connection
Regards
Re: Web space
29-10-2014 7:47 PM
Re: Web space
29-10-2014 8:30 PM
Yes, I can see your folder when in my FTP client
T
But am still unable to access using either Internet Explorer or Mozilla on both log on - Freenetname users or www.austerfield
Something appears most odd - is it my end or in the server?
Regards
Re: Web space
29-10-2014 9:26 PM
Re: Web space
30-10-2014 9:51 AM
I know that this is the correct URL but I cannot open it
Regards
Re: Web space
30-10-2014 9:52 AM
I am using Google DNS servers - what are you using
Re: Web space
30-10-2014 10:06 AM
C:\Windows\System32>nslookup www.austerfield.org.uk
Server: dsldevice.lan
Address: [REDACTED]
Non-authoritative answer:
Addresses: 212.159.8.151
212.159.9.151
Aliases: www.austerfield.org.uk
Re: Web space
30-10-2014 10:09 AM
C:\Users\Jim>tracert www.austerfield.org.uk
Tracing route to www.users.freenetname.co.uk [212.159.9.151]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 42 ms 32 ms 32 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189]
3 32 ms 32 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.188]
4 35 ms 32 ms 31 ms xe-9-1-0.pcl-cr01.plus.net [212.159.0.220]
5 32 ms 31 ms 32 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 38 ms 38 ms 38 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
7 39 ms 39 ms 39 ms vlan2657.ptp-elb01.plus.net [84.93.224.36]
8 38 ms 40 ms 39 ms www.users.freenetname.co.uk [212.159.9.151]
Re: Web space
30-10-2014 1:29 PM
If I go through Google I can find the site OK
However if I simply enter http://www.austerfield.org.uk I am directed to a site under Brian Austerfield heading Curriculum Vitae which says the site is the page is not in use
Obviously other persons entering http://www.austerfield.org.uk would also be directed to the same site - can this be deleted?
Regards
However all I can see through Google is Bob's comment "it works"
