VOIP Adapter
JamesCRocks
VOIP Adapter
I'm thinking of buying this VOIP adapter: Grandstream HT801 HandyTone
Anyone have any better advice?
James
40 REPLIES 40
Fixes: 1,495
Re: VOIP Adapter
I have the 812, this should be fine.
Any particular use in mind?
JamesCRocks
Re: VOIP Adapter
Thanks. I have DECT phones (quad set) which still work reasonably well. That and VOIP phones (probably the best solution) appear rather expensive.
James
JamesCRocks
Re: VOIP Adapter
What about this kind of adapter (the Linksys PAP2T I think)? It's cheaper than the Grandstream.
eBay: Internet VOIP Phone Adapter/Gateway
James
cpc6128
Re: VOIP Adapter
I spent a bit of time looking for a cheap ATA and I found a used N300IP (which I bought on ebay for about £20 - excludes P&P) which is connected to a  panasonic dect phone on an AAISP service.
RobPN
Fixes: 15
Re: VOIP Adapter
I've only ever used Gigaset handsets with my N300-IP, but I know from someone else's experience that certain features (e.g. call routing via the Dialling Plans) don't work with just any old GAP compatible handset.  He was actually using older Gigaset handsets which didn't fully work for him and ended up buying new ones which enabled the missing features to work.
YMMV, but there's a compatibility utility for Gigaset handsets and base stations at -
https://www.gigaset.com/hq_en/cms/service/compatibility/products.html
Fixes: 585
Re: VOIP Adapter
@JamesCRocks be careful with the PAP2T, many were locked to Vonage. Whilst earlier ones could be unlocked, some later firmware ones could not.
JamesCRocks
Re: VOIP Adapter
So this one?
Internet VOIP Phone Adapter/Gateway RJ45 Cable, Linksys PAP2T (UK Plug)
James
cpc6128
Re: VOIP Adapter
No, I was talking about another ATA the N300IP:
https://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2214-R601-1-TE43_02-05-2011_en_CZ_HR_PL_SK_S...
I am using a used one and there is another on Ebay UK for 19.99 + P&P.
I also went for this ATA because it has instructions for setup for use with AAISP VOIP which I use.
I haven't used the one you've linked to.
JamesCRocks
Re: VOIP Adapter
Fixes: 585
Re: VOIP Adapter
In theory, yes. The go box 100 is basically thevsame as the n300 ip. However, the ones advertised are German versions , so they will have eu plugs. I don't know whether the firmware will be different.
Amazon warehouse have used ones at £13.97 here https://www.amazon.co.uk/Gigaset-Station-Communication-System-Handsets/dp/B087XPLSW5/ref=sr_1_22?cri... so might be worth a punt if you can get an eu to uk adaptor
Fixes: 480
Re: VOIP Adapter
There is a comment on the Amazon page:
If it's like the Grandstream ones you will be faced with a mind boggling number of configuration options, presumably in German.
iannewson
Fixes: 5
Re: VOIP Adapter
PAP2T's are way beyond end of life. Even when they were current the were well known for having Chinese knock offs
iannewson
Fixes: 5
Re: VOIP Adapter
German telecom equipment also tends to use  TAE-F plugs so you might need to convert those to BT plugs.
Fixes: 118
Re: VOIP Adapter
@JamesCRocks
I have no knowledge of ATA's so can't offer advice there.
Do you have a current VOIP provider? If so, what do they recommend?
Are you thinking about moving to a VOIP provider? If so, what do they recommend.
Finally, if just looking to get set up for the end of PSTN consider waiting until you have to change. Then look at what's available and / or your chosen suppliers equipment.
