Usage
bogart99
Usage
Been asked before but is there currently anyway of determining my data usage per month?
8 REPLIES 8
Fixes: 388
Re: Usage
Not been possible for a long time - from memory, since plans became 'unlimited', although if you are very lucky and one of the experienced Help Team members sees this, and has time, they may be able to extract the data.
Ian06
Fixes: 6
Re: Usage
Some routers record volume off data sent/received... I can get daily reports from mine - but it is my own router and I suspect the Plusnet routers don't keep this information - other forum members may know....  @jab1  @Dan_the_Van
Fixes: 388
Re: Usage
@Ian06  - the Hubs do not log this information.
bogart99
Re: Usage
I use my own router but it does not keep details
Fixes: 388
Re: Usage
In that case, @bogart99 , I think the answer to your question is no, to be honest.
Re: Usage
@bogart99
If you are using a plusnet Hub (which you are not) but helpful for others
If I recall correctly the Hub One records the total Data sent/received for the period the Hub has been powered on and active
Navigate from the home page >Troubleshooting >Help desk >Line 11
This reset if the Hub One is rebooted
The Hub Two Data usage is for the period the broadband user has been logged in
Navigate from the home page >Advanced settings >Broadband  >look for the line Data usage:
For the Hub two you can see that data usage for an individual device
Home >My device (from what I can see the data usage against the device is the total for the device since it connected to the Hub)
HTH
bogart99
Re: Usage
Alas such is life.
Fixes: 1,495
Re: Usage
Moderators Note
This topic has been moved from Broadband to Everything Else
