Update reverse DNS for static IP
exterrestris
I recently did a reverse lookup on the static IP associated with my account, and found that it references a domain that I have no knowledge of - I'm assuming it was set for a previous user of this IP. I already have my own domain pointing at the IP - could I get the reverse DNS updated to match please?
1 REPLY 1
Tina11192
Fixes: 18
Re: Update reverse DNS for static IP
Hi @exterrestris thanks for getting in touch with us.
I will raise this to our NetOps team to update however, could you advise me what information should the rDNS be showing. Once I have your response I will raise this off and provide you with a task reference.
I look forward to hearing from you soon
Cri Ignatti
