Unable to connect to certain websites
- Everything else
- Re: Unable to connect to certain websites
- « Previous
- 1
- 2
- Next »
19-08-2026 5:56 PM
"The server at www.theomoye.co.uk is taking too long to respond."
I can connect to it instantly. Sounds like one of those old 'Routing issues' that we have seen before.
19-08-2026 5:58 PM
Agreed, @pvmb , which is why I asked for the tracert.
19-08-2026 6:03 PM
@Tringo34 wrote:
How do I do that?
This may help: https://www.hostgator.com/help/article/how-do-i-run-a-traceroute-on-a-mac
19-08-2026 6:04 PM - edited 19-08-2026 6:05 PM
dnschecker.org have a tracing tool. There's a blockage at step 5, helpfully identified as ? ? ?
I did the trace again with the VPN turned on and got the same result but the website loads.
19-08-2026 6:05 PM
Try enabling and disabling Apple Relay, it works like a VPN when enabled.
19-08-2026 6:11 PM
I understand you need an iCloud+ account to access Private Relay. I don't have that and I'm using Firefox (same behaviour on Safari for what it's worth)
19-08-2026 6:19 PM
That 'blockage' could well be because that server doesn't respond to ping requests - some don't.
Also, the response times from hop 7 onwards look a little 'long'.
19-08-2026 6:44 PM
This website is not helpful, because it does a trace from some where in the world that we know not.
It is your computer / your connection that has this issue.
You need a trace from you own laptop / computer to these websites.
19-08-2026 8:28 PM
Thanks, that makes sense. So to run trace a route on Mac just run 'traceroute <domain>' via the command line.
The screenshots attached are without (when it stalls) and then with the VPN.
20-08-2026 9:37 AM
Everything seems to be working again this morning. Very odd.
20-08-2026 9:40 AM
Have you had any drops overnight? It could have been an issue with your public IP.
20-08-2026 12:12 PM
Not to my knowledge. I've read related posts which seem to indicate an IP problem.
20-08-2026 12:18 PM
If it was an 'IP problem', then only a change of IP, which would in involve a PPP drop, would have solved it.
- « Previous
- 1
- 2
- Next »
- Everything else
