Unable to access one website
Re: Unable to access one website
@markcaldwell83
It is annoying, after being asked which DNS you're using by a plusnet support member they appear to have ignored this thread.
Maybe a superuser @MisterW or @Townman can escalate the issue to the network team?
Champnet
Fixes: 21
@Dan_the_Van wrote:
@Champnet
Unless the ZEN DNS servers are public facing I doubt they will resolve anything, for me using one of the IP addresses you quoted
This confused me as changing the windows network settings to Zen DNS servers most sites still worked.
File this under "Things I should have known but didn't"
Apparently Windows holds 3 DNS entries. 2 manual & 1 from the DCHP settings, which may be 2.
Therefore in my example by manually changing to Zen DNS, site lookups would fail but moving onto the DHCP entries could be successful.
In the first case I would always use "nslookup" as this way you can specify the DNS server to use (local or something else)
I've filed this under "Things I knew once but have forgot about" Old age thing!
Champnet
Fixes: 21
 I don’t subscribe to that theory…..
Getting back on topic - anyone heard anything that could help @markcaldwell83 ‘s problem ?
nslookup www.pkbstatus.com
Server: cdns01.plus.net
Address: 212.159.6.9
*** cdns01.plus.net can't find www.pkbstatus.com: Non-existent domain
nslookup pkbstatus.com
Non-authoritative answer:
Addresses: 15.197.142.173
3.33.152.147
My broswer finds the website 'unreachable' to www.pkbstatus.com and pkbstatus.com. My browser is using default DNS.
telnet pkbstatus.com 80
^c
HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Fri, 11 Oct 2024 21:59:09 GMT
Content-Type: text/html
Content-Length: 122
Connection: close
<html>
<head><title>400 Bad Request</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
</body>
</html>
Connection to host lost.
"A 400 Bad Request Error occurs when a request sent to the website server is incorrect or corrupt, and the server receiving the request can't understand it."
<shrug - dunno>
Fixes: 580
Seems to be resolving fine now from both sets of PN DNS servers and the Safeguard ones
Champnet
Fixes: 21
Unfortunately no change here :
C:\Users\xyzzy>nslookup www.pkbstatus.com
Server: UnKnown
Address: 192.168.1.1
*** UnKnown can't find www.pkbstatus.com: Non-existent domain
C:\Users\xyzzy>nslookup www.pkbstatus.com 212.159.6.9
C:\Users\xyzzy>nslookup www.pkbstatus.com 212.159.6.10
Server: cdns02.plus.net
Address: 212.159.6.10
*** cdns02.plus.net can't find www.pkbstatus.com: Non-existent domain
markcaldwell83
Thanks all, is there anything I can check at my end or do I need plusnet support to step in?
Fixes: 580
Ah! my bad I'm afraid, I was checking the bare domain pkbstatus.com
@Champnet is correct , www.pkbstatus.com still doesnt resolve using the PN DNS servers
markcaldwell83
Hi all, I have no idea why but it's working on Chrome.
Thank you for all the support, another mystery I guess!
RealAleMadrid
Fixes: 68
@markcaldwell83  Something has been changed, the site works now on windows10 Edge using the Plusnet DNS servers.
Champnet
Fixes: 21
Looks good…….
Using Edge, DuckDuckGo & Safari.
