Unable to access Plusnet website
bobpullen
Fixes: 331
Re: Unable to access Plusnet website
As a few have already reported, this should now be sorted.
A new cert has been installed that omits the errant SHA-1 sig in the chain.
Thanks to those that raised the flag, and apologies it took a while.
dvvrue95
Hi folks,
just another confirmation the PN flag fix appears to have solved the problem for me
I am using a Chromebook with the current Chrome Version 116.0.5845.210 (Official Build) (64-bit).
Have reset TLS to default within Chrome and can now access PN web sites.
Smiley Smiley Smiley
RevvyRevRev
I've reset SHA-1 to default - and all working fine.
Many thanks.
landf24_comm
Chrome on android - I've also reset SHA-1 to default - and all working fine.
thanks
