Transfer out .co.uk domain
Alex_H
Re: Transfer out .co.uk domain
Hi @cja,
I have sent you a private message to help with your domain transfer out request.
Alex
plusnettony
Fixes: 56
I did a few to the tag eukhost yesterday.
They are a little problematic, in that you need to engage with them as well before the tag change is accepted.
 Tony T
cja
😁 all done btw.
Yes people outside the IT industry imagine it's all smooth and automated.. if you work in it you know that is often not the case 🤣
Thanks for your help.
