Transfer domain to Plusnet
stevebonline
Grateful for the URL of where this is possible on P-N, or instructions, please.  I have a UK domain and have transferred the tag to FORCE9.
5 REPLIES 5
Fixes: 579
Re: Transfer domain to Plusnet
@stevebonline Sorry to be the bringer of bad news, but AFAIK Plusnet will not accept domain transfers in (and haven't for some time!)
willcutforth
Fixes: 113
@MisterW is right. There are no more transferring in of domains. Sorry about that.
 Will Cutforth
Fixes: 476
Moderator's note:
Thread moved from My Account/Billing to Everything Else
stevebonline
That "fixed my problem", thanks, although the news is not welcome.
Having moved the IPTAG to FORCE9, any ideas how I can recover it from FORCE9, please?
Fixes: 579
Assuming you just changed the tag using your current registrar's control panel, can't you just either change it back or change it to the new registrar
