Thinking of switching to Plusnet - Contact?
drallcom3
Hello,
I'm thinking of switch to Plusnet. I do have questions first though. On the website I only found a phone number (and even that one was quite hidden). I'm deaf and can't use the phone. Is there a web chat or email address for general questions?
Thank you
6 REPLIES 6
mystreet1
Seasoned Pro
Fixes: 7
Re: Thinking of switching to Plusnet - Contact?
Only phone unfortunately.
But, you can use the BT relay service for all calls.
https://www.relayuk.bt.com/
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 357
@drallcom3 If your questions are of a general nature, you will probably get quicker answers on here, from members of the community.
Fixes: 105
@drallcom3
If you do join PN, then you can Register as a "vulnerabe person" online via your Members page. This should help (???) with communications in so much as it's recorded by PN that you are deaf.
drallcom3
I know this community is quite helpful, but imagine I'd have to call support. Which I already know I will have to when I switch to Plusnet and there's nothing the community can do about it, no matter how helpful and nice they are.
Fixes: 357
For the actualswitch, from another provider, you don't need to call either PN  or your current provider if you use the OTS (One Touch Switch) function.
Mav
Fixes: 518
Moderator's note(s):
Thread moved from My Order to Everything Else.
Forum Moderator and Customer
