Subdomains
- Everything else
- Subdomains
Subdomains
01-09-2010 8:51 PM
Is there anyway I get my domains to work thus:
www.domain.co.uk : points to the ccgi server (this is done, and working)
home.domain.co.uk : points to my own home PC via IP address (I have a static IP address, and the router is all setup)
I've configured the DNS settings thus:
home A <IPAddress>
www CNAME ccgi.plus.net.
However, www.domain.co.uk works but home.domain.co.uk does not. However, http://<IPAddress>; works.
Or would it be simpler to get another domain to point to my IP address?
Thanks in advance,
Gerald.
home A <IPAddress>
Thanks in advance,
Gerald.
Message 1 of 6
(1,211 Views)
5 REPLIES 5
Re: Subdomains
02-09-2010 8:59 AM
I think that should work.
I do something similar, so I wonder what I'm missing.
Personally I'd use all a records, but that shouldn't matter:
home.domain.co.uk. a 123.123.123.123
domain.co.uk. a 84.92.1.4
www.domain.co.uk. ; a 84.92.1.4
What do you get when you call home.domain.co.uk?
Gabe
Gabe
Message 2 of 6
(293 Views)
Re: Subdomains
02-09-2010 8:41 PM
Well, I never...it works now. Prolly didn't leave it long enough after making the change - gave it about 12 hours.
Anywho, thank you Gabe.
Gerald.
Gerald.
Message 3 of 6
(293 Views)
Re: Subdomains
02-09-2010 8:51 PM
DNS changes on your account often take over 24 hours to action, plus time for the changes to propagate out into the internet DNS cloud.
Message 4 of 6
(293 Views)
Re: Subdomains
10-09-2010 10:27 AM
Addition of a sub domain does not require any time to propagate. Only when the IP of the nameserver hosting the main domain is changed is time required for propagation.
When I add sub domains to any of my DNS servers the results are available instantly.
Message 5 of 6
(293 Views)
Re: Subdomains
10-09-2010 11:22 AM
Our internal Domain Control System takes 4-8 hours to update between the API and the DB so this probably accounts for the delay seen
Message 6 of 6
(293 Views)
