Static IP
orllewin
Static IP
Hi, I registered for a static IP when I signed up but the web interface to activate it seems broken (and judging by several other topics has been for a long long time...).
How do I activate it? It seems like the done thing is to post here and wait for support staff to do it manually?
I have clicked the unresponsive Activate Your Static IP button many times and powercycled the router.
Thanks,
J
3 REPLIES 3
Mav
Fixes: 518
Re: Static IP
Moderator's note(s):
Thread moved from Broadband to Everything Else.
Forum Moderator and Customer
Champnet
Fixes: 21
Re: Static IP
@orllewin  You've done the right thing posting here, a member of staff should be along to action your request.
Welcome to the forum...............
MatthewWheeler
Fixes: 503
Re: Static IP
Hi @orllewin
That should be sorted now.
If you reboot the router you'll pick it up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
