Static IP is dynamic
- Everything else
- Re: Static IP is dynamic
29-01-2024 8:32 PM
My static IP is not very static and the UI for enabling it doesn't seem to be broken. I've seen others with the same issue asking in here so could a staff member enable it for me please!
Message 1 of 2
(710 Views)
1 REPLY 1
31-01-2024 5:30 PM
Hi @Ian86
I've managed to get that sorted out for you now
If you reboot your router you'll get the static IP assigned
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 2 of 2
(626 Views)
- Everything else
