Static IP addresses no longer available?
jafwatt
I called PN support to request a static IP address and was told these are no longer available?
Just wanted to check this is true?
5 REPLIES 5
RealAleMadrid
Fixes: 68
Re: Static IP addresses no longer available?
@jafwatt  Yes it is true.  They were stopped around December 2024.
Static IP no longer available
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Everything Else
poweredbyveg
So because the ipv6 trial can only be used with a static ipv4 address, what happens when this is rolled out to everyone? Will PN offer static IP addresses again?
RealAleMadrid
Fixes: 68
@poweredbyveg  The current IPV6 trial is for users on the "High touch network" who already have static IP addresses.
See High Touch Trial
There will presumably sometime in the future be another trial for users with Dynamic IP addresses on the "Low touch Network"  There was a small scale attempt at this over a year ago with just one user connected and it failed.🤔
The Low Touch network will always use dynamic addresses.
Fixes: 249
No, static IP addresses are no longer part of the business offering.
