Static IP activation problem
- Everything else
- Re: Static IP activation problem
06-04-2024 12:21 PM - edited 06-04-2024 12:22 PM
Hello.
I have a problem with activating static IP.
I have purchased the service, but after pressing the activate static IP button, I still have a dynamic IP address.
Can you fix this, please?
Arkadiusz P.
Message 1 of 2
(688 Views)
1 REPLY 1
06-04-2024 4:06 PM
Hi @praslay
That should be fixed for you now.
If you reboot your router you should pick the new static IP up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 2 of 2
(660 Views)
- Everything else
