Sky glass/ Sky Stream
FIXEDTopic Options
- Everything else
- Re: Sky glass/ Sky Stream
17-10-2022 5:20 PM
I am currently receiving Plusnet unlimited fibre broadband. I’m considering subscribing to the new Sky stream tv service. Has anyone who currently has Sky Glass had any problems with streaming. Is unlimited fibre sufficient or would unlimited fibre extra be better?
Fixed! Go to the fix.
Message 1 of 2
(1,719 Views)
1 REPLY 1
20-10-2022 1:15 PM
A quick Google suggests you'd need a minimum of 10mbps to stream HD content and 25mbps for 4K, so Unlimited Fibre should be fine for this. How fast do you currently get? Run a speed test Here ![]()
Message 2 of 2
(1,641 Views)
- Everything else
