Sharing files using PN webspace
- Everything else
- Sharing files using PN webspace
19-04-2013 10:36 AM
I used CUTFTP to upload to /htdocs folder.
Any advise would be appreciated.
Thanks.
Forum Moderator and Customer
Re: Sharing files using PN webspace
19-04-2013 10:44 AM
If you want me to have a play to see if I can replicate the problem send me the file name by PM
19-04-2013 11:08 AM
My daughter also got the request for the login/password details on her laptop.
I have uploaded another rar with just 1 photo to the same folder and the above still requests the login/password.
On reflection I think I gave the wrong URL (ftp://ftp.plus.net/htdocs/Kay%20Birthday.rar). But trying www.PNname.plus.com/htdocs/kay_birthday.rar gives "Access Error: 404 -- Not Found".
19-04-2013 11:34 AM
The correct link is www.myusername.plus.com/filename
19-04-2013 11:41 AM
But using www.myusername.plus.com/filename is still giving the 'Access Error: 404 -- Not Found' error. As far as I know the filename is case sensitive and must include the extension (.rar in this case) and I have checked for this.
So, next question, should the file be placed in the thdocs folder or elsewhere?
Edit: CuteFTP wouldn't allow me to load the file to the root folder (the folder containing htdocs).
19-04-2013 12:10 PM
I was just entering myusername.plus.com/filename
... as soon as I entered www.myusername.plus.com/username then all is well
Edit: I am interested in knowing why omitting the 'www.' would make such a difference?
19-04-2013 12:20 PM
19-04-2013 12:23 PM
Quote from: Mav Edit: I am interested in knowing why omitting the 'www.' would make such a difference?
Because without the www by default it points to your router not the web server!
Uploading a file that size to your Plusnet web space is not a good idea. It's probably dangerously close to the maximum amount you can have on your webspace and if two or more people download it on the same day you'll get nasty emails from the abuse department and your entire website will be removed.
19-04-2013 12:35 PM
19-04-2013 12:38 PM
@jelv That explains about the www bit.
Thanks for the warning about the file size. As it was only my daughter to download and I was going to remove as soon as she had anyway I didn't foresee any issues but I take your point. Probably better to use SkyDrive or Dropbox next time. Dunno why I forgot about those this time
@purleigh Thanks for additional info. Hate those 'naughty schoolboy' type emails when you have gone over the limit.
19-04-2013 2:32 PM
Just a thought - 230MB is space enough for quite a lot of very large images. Is your daughter going to print 20"x30" posters of these pictures?
If they are just to be viewed on a monitor or printed at, say, 6"x4" then resolutions of about 1500x1000 pixels would be mored than adequate, and each image file needs to occupy only perhaps 100kB.
Modern digital cameras produce files that are much bigger than most people need for most purposes. Fine for the occasional picture that really needs it, but very wasteful otherwise. I think there are many ways of reducing image files sizes to make them more suitable for sharing. Worth considering?
Keith
19-04-2013 3:48 PM
Anyway, what I didn't make clear is that I logged on to my daughter's Laptop using LogMeIn and entered the password myself.
Next time I'll have time to reduce sizes, etc... 3 years when she's 21
- Everything else
