Second Broadband line.
kiefels
Would it be possible to have a second broadband line connected?
Getting a little bit fed up with trying to stream whilst, gaming is going on in another room.
I know it's feasible but is it as simple as plugging in another router in a different phone point and setting up another network?
14 REPLIES 14
Fixes: 386
Re: Second Broadband line.
Nope - not that simple, you need a completely new line, and I'm not that certain you can get then since the stop-sell on copper came into effect.
Fixes: 118
@kiefels
It would be helpful to know what is available to you network wise. If you can post a screen image from the following (after hiding your details) it would help Members to provide advice.
If possible, you'd need to pay for a second account.
HPsauce
All Star
Fixes: 5
@kiefels  In a word "YES" I did it. You will have to phone in though and it will be a separate account extra cabling and probably have an installation charge. BTOR "should" also check (once the order is placed) that you really do want an extra line and the existing one is to remain.
What's available will depend on the exact situation where you are and the rules set by BTOR.
I added a FTTC (SOGEA) line in parallel to my old ADSL/POTS  copper-to-the-exchange line. 60mbps vs 19mbps.
I was lucky in that the overhead cable to my house already had four pairs in it so the engineer had an easy job finding an unused pair for the line. I also pre-drilled a hole for his cable having worked out exactly where I wanted the new (additional) master socket.
I should also add that in due course I terminated the old ADSL service, transferred the phone number to VOIP (with A&A) and totally ceased the original line. Oddly it still has a dial tone and a (different) number allocated, though it won't make or receive calls other than engineer tests.
Fixes: 386
Reading your post, @HPsauce makes me think I may have been wrong, but it all depends what this says if the customer enters their phone number : BT Broadband
HPsauce
All Star
Fixes: 5
 as @bmc said, that information is needed to advise further and/or decide.
Fixes: 386
Sorry, must have missed/forgotten that post. Embarrassed
@jab1
I thought the stop sell was for WLR (Wholesale Line Rental) which is for landline phones, so any new connection would be SoGEA (Single order Generic Ethernet Access) where FTTP is NOT available.
Fixes: 386
Maybe I should have been clearer in my reply to @HPsauce - I have realised that unless the OP is in a Fibre Priority area, they can still get a SoGEA connection.
kiefels
@bmc  Hey, thanks for your answer, and I apologise for the extremely late reply.
Life and illness ceased the progress of this project.
Anyway
I give you the info you asked for.
Many thanks, for the assist, as all the Initialisms
Fixes: 118
@kiefels
Thanks for the information.
You should be receiving between 44 and 59 down. Can you run a speed test to check? If possible it needs to be on a wired connection with nothing running in the background.
How are the devices connected? If WiFi then this could be the problem, not the actual connection itself.
While I believe a second line is possible I'm not sure how it would work. You'd need a separate account with PN (or any other ISP) and would be paying two bills.
kiefels
Wired i'm receiving around 46,  wireless 42.
I'm aware I may require a second account but my main concern is extra cabling. By that I mean, BT dragging in new lines.
I have no overhead cables as my estate is only 13 years old, all BT cables are underground.
So cost is probably negate my need.
Thanks for the info though
With all of this technology, we still rely on good old cables
@kiefels
I had a new build property back in 1994, Openreach used a multi core cable (more than one pair) to the property. You may find yours to be the same,
Fixes: 118
@kiefels
You could take the face plate off the Master Socket and have a look at the incoming cable. It may have two or four twisted pairs. As a line only requires one pair then a second line could use one of the other pairs.
Others may comment on this but I think you would need a second Master Socket, router and power source.
HPsauce
All Star
Fixes: 5
@kiefels I don't think the installation charge will change whatever cabling you currently have, though it's very likely to have spare pairs in it. If it doesn't they'll have to pull in a replacement.
As for checking the master socket, worth doing, though it may not prove much if there's a joint/junction between the main external underground cable and the socket.
