Safesearch inconsistently enforced
bobpullen
Fixes: 330
Re: Safesearch inconsistently enforced
@CuriousSideny - thanks, seems you're hitting the same servers/data centres as me so I'm unsure why I'm not seeing what you are 🤔
With the lookups, could you modify the command to specify the DNS server address so we know for sure that's what it's hitting (or just use the nslookup command I suggested)?
@Townman - no, not aware. Is it the error banner that pops when modifying settings? I was seeing that myself when trying to replicate this issue and assumed it was something specific to my account.
CuriousSideny
Hi Bob,
In my first response I was using the same command you specified to capture them:
     "nslookup -type=TXT -class=CHAOS id.server 213.120.234.42"
Is that okay or do you want me to try something else?
Thanks!
HPsauce
All Star
Fixes: 5
I don't know if it's relevant but I've seen some really weird Safesearch behaviour in recent weeks.
In Google searches I would notice that it had been turned on and that there was a message saying I couldn't turn it off as it was enforced externally via an administrator (wording guessed from poor memory).
Yet closing the browser (usually Edge) and reopening it would remove Safesearch.
After the recent DNS problems I changed away from router (Hub2) i.e. PN-supplied DNS to independent services. This weirdness no longer happens. It's consistently off as my Google accounts specifies.
The interesting thing here is NOT ONLY that Safesearch was inconsistent BUT it was being imposed when NOT ASKED FOR!
Not sure which is worse, censorship you've not asked for or censorship that is inconsistent........
bobpullen
Fixes: 330
@HPsauce - thanks for sharing your experience. Those symptoms are exactly what we're trying to get to the bottom of.
@CuriousSideny - it's the website (or Google Safesearch) lookups that would be handy rather than the server ID ones. i.e: -
> nslookup pof.com 213.120.234.42
Above assumes that you have dating websites blocked. Substitute pof.com for another website that falls into a category you do have blocked if not.
Specifying the Safeguard DNS server address just removes any ambiguity around what DNS server is replying to your lookups.
HPsauce
All Star
Fixes: 5
Thanks @bobpullen but unfortunately I can't really give you any more useful information. I must say I did find it really quite weird and inexplicable.
As a retired IT guy I could probably have given more detailed analysis with a bit of effort but it wasn't a significant annoyance to me and I've now bypassed it.
CuriousSideny
Thanks @bobpullen I ran "nslookup pof.com 213.120.234.42" in a loop for ~5 minutes and got:
2488 : Server: indnsc92.bt.net Address: 213.120.234.42 Name: pof.com Address: 81.130.111.239
1342 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 Name: pof.com Address: 81.130.111.239
633 : Server: indnsc92.bt.net Address: 213.120.234.42 Name: pof.com Addresses: 104.18.36.63 172.64.151.193
358 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 Name: pof.com Addresses: 104.18.36.63 172.64.151.193
(The number at the start is just the number of times it returned that result.)
Fixes: 246
@bobpullen  - yes the banner issue when attempting to modify safeguard settings.
@CuriousSideny  - for the avoidance of doubt, can you affirm that there’s no transcription error in those server names - otherwise identical URLs with and without ‘ukcore’ seems suspicious.
@bobpullen - I note two IP addresses returned - is one “safeguarding” and the other the site?  Is it possible to construct a command which identifies the DNS service instance which provided the response?
AIUI the DNS ‘server’ is in reality a pool of service instances (each with their own database) which creates the possibility of the same ‘server’ delivering variable results … as I’ve seen when tracking a domain migration - the same DNS ‘server’ randomly returning both the old and new IP addresses.
Could such be similarly responsible for the safeguarding DNS delivering inconsistent results … an out of step instance delivering non-safeguarded resolutions?  As a diagnostic is it possible to address the DNS instances direct?  How many are there?
CuriousSideny
Hi @Townman, this was copy pasted from the outcome of a script that captured/collated the result so I'm pretty confident that I didn't introduce any transcription error. I also have run it manually and see the same thing (i.e. sometimes indnsc92.bt.net and sometimes indnsc92.ukcore.bt.net).
Thanks!
bobpullen
Fixes: 330
@CuriousSideny - thanks for that, seems conclusive (not that I doubted you!)
I've not given up yet...
CuriousSideny
Thanks @bobpullen - I do really appreciate that!
CuriousSideny
@bobpullen, unless this is a freak occurrence, I would say that the issue may have resolved itself at some point either yesterday or today.
It seems like the google safesearch url is now correctly always resolving to forcesafesearch.google.com.
It would be great if any correlation could be made with any changes by Plusnet or the underlying BT infrastructure that might have led to this, in case it happens again. That way we might be able to point them in the general direction.
bobpullen
Fixes: 330
@CuriousSideny - we previously identified some inconsistencies in the application of some automated config that would have resulted in the symptoms being seen.
To be honest, I was under the impression we'd addressed this before now, but will see if there's a correlation with anything that may have been done last week.
Thanks for updating.
Edit: I'm informed that there was some patching activity last week that may have kicked any remaining 'rogue' servers into touch.
CuriousSideny
@bobpullen @Townman, it seems like the same symptoms have come back again. I repeated the tests mentioned earlier in this thread and the same results were observed. Any thoughts on how this can be resolved?
Thanks,
Sid
CuriousSideny
Actually, it now seems to be back to working again (as of last night). I guess the issue was short lived.
bobpullen
Fixes: 330
@CuriousSideny - do shout again if the situation changes!
