Safesearch inconsistently enforced
CuriousSideny
I've created a separate ticket to https://community.plus.net/t5/Everything-else/Safeguard-not-enforcing-google-safe-search/td-p/200040... because it's marked as fixed and so I can't respond to it, but in any case I think the issue is different this time to before.
So for clarity the issue is that SafeSearch isn't force enabled in the various search engines in the way it was about a week ago.
I've investigated myself and I've noticed that if I keep re-opening the browser and attempting to search for something dodgy *sometimes* (rarely) safesearch is enforced and other times it isn't.
On a hunch I did some DNS lookups and I can see that sometimes it maps to forcesafesearch.google.com as I want:
Resolve-DnsName www.google.com | Select-Object Name, IPAddress
Name IPAddress
www.google.com
forcesafesearch.google.com 2001:4860:4802:32::78
forcesafesearch.google.com 216.239.38.120
And most other times it does not:
Resolve-DnsName google.com | Select-Object Name, IPAddress
Name IPAddress
google.com 2a00:1450:4009:c04::8b
google.com 2a00:1450:4009:c04::65
google.com 2a00:1450:4009:c04::66
google.com 2a00:1450:4009:c04::71
google.com 142.250.117.139
google.com 142.250.117.100
google.com 142.250.117.102
google.com 142.250.117.113
google.com 142.250.117.101
google.com 142.250.117.138
I would guess that might be an issue with the underlying BT DNS that it isn't doing this consistently, so maybe that will help at making some progress.
@bobpullen @Townman
29 REPLIES 29
PhilipHeyes
Seasoned Pro
Fixes: 10
Re: Safesearch inconsistently enforced
For stability and reliability I avoid an ISP DNS if it is capable of DNS Content Filtering or performs DNS Redirection or lacks support for DoH / DoT.
Retry the DNS lookups with Google and Cloudflare's Public DNS, see if the results are any better.
1) nslookup www.google.com 8.8.8.8
2) nslookup www.google.com 1.1.1.1
You can also check out the lookup over a wider range of Public DNS at : https://www.nslookup.io/
CuriousSideny
Is there anyone looking into this? Until a few weeks ago this was working fine. Nothing has been changed on my end, and yet the SafeSearch feature is not often being force enabled as it was before (very rarely it is force enabled).
bobpullen
Fixes: 330
@PhilipHeyes - using a third party DNS resolver is not going to help here; it would just bypass the Plusnet Safeguard enforcement of Safesearch entirely.
@CuriousSideny - I had not seen this thread as I was expecting a reply to my post elsewhere.
Are your DNS queries definitely hitting the Plusnet/BT servers each time you run them?
Perhaps you could confirm by using a command where the DNS server to be used is being explicitly specified? e.g: -
> nslookup www.google.com 213.120.234.42
In fact, might be worth trying both of the DNS IP addresses to see if there's any difference between the two?
213.120.234.38
213.120.234.42
CuriousSideny
Thanks @bobpullen - I wasn't able to reply to the other thread for some reason - there is no option to allow me to do so.
Here are the results I get when I tried your two examples:
nslookup google.com 213.120.234.42
Server: indnsc92.bt.net
Address: 213.120.234.42
Non-authoritative answer:
Addresses: 2a00:1450:4009:c17::8b
2a00:1450:4009:c17::71
2a00:1450:4009:c17::65
2a00:1450:4009:c17::64
142.251.30.139
142.251.30.113
142.251.30.101
142.251.30.102
142.251.30.138
142.251.30.100
nslookup google.com 213.120.234.38
Server: indnsc102.ukcore.bt.net
Address: 213.120.234.38
Addresses: 2a00:1450:4009:c17::64
2a00:1450:4009:c17::8a
2a00:1450:4009:c17::66
142.250.151.101
142.250.151.102
142.250.151.138
142.250.151.100
142.250.151.113
142.250.151.139
If I repeat with the .42 address then sometimes it says indnsc92.ukcore.bt.net and sometimes indnsc92.bt.net but no change otherwise.
bobpullen
Fixes: 330
@CuriousSideny - just activated Safeguard on a Plusnet line line and given things a go.
google.com seems to do as it does for you. Using the www.google.com subdomain instead is a little more interesting.
Sometimes does what I'd expect: -
Addresses:  2001:4860:4802:32::78
          216.239.38.120
Aliases:  www.google.com
Sometimes doesn't: -
Addresses:  2a00:1450:4009:c0f::93
          2a00:1450:4009:c0f::67
          2a00:1450:4009:c0f::69
          2a00:1450:4009:c0f::68
          216.239.38.120
It's the same if I carry out a lookup against a domain I would expect to be blocked by one of the parental controls categories (dating, in this case): -
One minute blocked: -
> nslookup tms.eharmony.co.uk 213.120.234.42
Server:  indnsc92.ukcore.bt.net
Address:  81.130.111.239
The next not: -
Addresses:  104.21.67.133
           172.67.176.232
Will see what else I can uncover. In the meatime I'd be insterested to hear if you have the same problem with a site that should be blocked by one of the category filters?
CuriousSideny
Thanks @bobpullen: you seem to be correct that it also applies to the category domain filters too. I just brought up Chrome attempted to browse to https://www.eharmony.co.uk/ and then closed it multiple times and most of the time it blocked it, but then occasionally it browsed through to the site itself. I also repeated your experiment and got the same results as you did.
I guess I hadn't noticed that because it's only when doing an image search that I spotted the original problem.
bobpullen
Fixes: 330
@CuriousSideny just a note to say that I haven't forgotten about this one.
CuriousSideny
I appreciate that Bob - thanks for letting me know!
bobpullen
Fixes: 330
@CuriousSideny at the slight risk of speaking too soon, I reckon we might be in a better place now if you fancy checking things at your side?
CuriousSideny
Hi @bobpullen,
I'm afraid I still don't see any difference in behaviour (tested against multiple devices).
bobpullen
Fixes: 330
@CuriousSideny - hmm, that's frustrating.
So, to be clear - if you run repeated lookups to a domain you expect to be blocked, you sometimes see the 81.130.111.239 IP returned and sometimes don't? My testing was consistently returning the 81.130.111.239 IP which is what I would expect. Don't suppose you can provide some examples?
In addition, try running this a handful of times and make a note of the string that's returned (it will probably be different each time but it would be interesting to see what servers you're hitting): -
> nslookup -type=TXT -class=CHAOS id.server 213.120.234.42
 You're looking for something like 'clpnd13-2'.
Fixes: 241
@bobpullen
I am NOT using safeguarding, but get the following...
        "chpnd13-1"
DNS request timed out.
    timeout was 2 seconds.
id.server       text =
        "chpnd11-4"
        "chpnd15-2"
        "chpnd15-2"
        "chpnd12-3"
        "chpnd11-4"
        "chpnd14-1"
        "chpnd12-3"
        "chpnd15-2"
        "chpnd13-1"
        "chpnd14-1"
        "chpnd12-3"
Does this help any?  I chopped out all of the guff (aside from the DNS time out response).  Let me know if more detailed querying would help and I'll try to set up some automation.
Are you aware of the incident which is impacting the administration of safeguarding settings?
CuriousSideny
Thanks @bobpullen (and @Townman for your info). I ran this in a loop for 2 mins and got the following (the number at the start is the number of times that result came up):
516 : Server: indnsc92.bt.net Address: 213.120.234.42 id.server text = "chpnd12-3"
502 : Server: indnsc92.bt.net Address: 213.120.234.42 id.server text = "chpnd15-2"
486 : Server: indnsc92.bt.net Address: 213.120.234.42 id.server text = "chpnd11-4"
468 : Server: indnsc92.bt.net Address: 213.120.234.42 id.server text = "chpnd13-1"
424 : Server: indnsc92.bt.net Address: 213.120.234.42 id.server text = "chpnd14-1"
120 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 id.server text = "chpnd15-2"
109 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 id.server text = "chpnd13-1"
108 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 id.server text = "chpnd14-1"
100 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 id.server text = "chpnd11-4"
83 : Server: indnsc92.ukcore.bt.net Address: 213.120.234.42 id.server text = "chpnd12-3"
CuriousSideny
I performed some more DNS resolving and see examples as follows.
Result which seems to correctly redirect to forcesafesearch.google.com:
Name IPAddress
www.google.com
Result which seems to incorrectly redirect at least for Ipv4 addresses:
Name IPAddress
www.google.com
www.google.com 192.178.223.147
www.google.com 192.178.223.104
www.google.com 192.178.223.106
www.google.com 192.178.223.99
www.google.com 192.178.223.105
www.google.com 192.178.223.103
And:
Name IPAddress
www.google.com 2a00:1450:4009:c0f::63
www.google.com 2a00:1450:4009:c0f::6a
www.google.com 2a00:1450:4009:c0f::68
www.google.com 2a00:1450:4009:c0f::93
