SOGEA
- Everything else
- SOGEA
SOGEA
25-04-2018 3:06 PM
i have just checked my exchange , i noticed that Single Order Generic Ethernet Access (SOGEA) is available ?
yes i know its just testing are PN taking part ?
Re: SOGEA
26-04-2018 5:08 PM
Re: SOGEA
26-04-2018 5:14 PM
@HarryB Thanks
as they say , you dont know if you dont ask
Re: SOGEA
26-04-2018 5:19 PM
Out of interest, why do you ask?
Moving you on to SOGEA would make zero difference to the quality of your connection, as everything E-side would remain as it currently is.
Re: SOGEA
26-04-2018 8:38 PM
I noticed this as I did a check on my line....
Customer and Forum Moderator. Windows 10 Firefox 101.0.1 (64-bit (64-bit)
Re: SOGEA
26-04-2018 8:47 PM
If I understand it you wouldn't need the voice part of the line and thus an expected reduction in price?
Re: SOGEA
26-04-2018 9:17 PM
Despite Plusnet's highly dubious pricing of the FTTP "Trial" when you're not paying line rental, I don't think any significant reduction in price is realistic.
Re: SOGEA
27-04-2018 8:22 AM
Re: SOGEA
27-04-2018 8:56 AM
TBH our phone line is basically unused as 99percent of call are via mobile device
Re: SOGEA
27-04-2018 10:51 AM
I would assume that the SOGEA price difference would be measure in double digit pennies.
That is just going from the FTTP price differences at ZEN for FTTP plus copper phone line against FTTP with no phone line. I know it is a different product but the costs are in supplying and maintaining the infrastructure. The profit margin to the company comes from the calls made.
Re: SOGEA
19-05-2018 1:50 PM
Have just found this so if i read correctly it not bad saving on cost
• SOGEA connection pricing of a premise currently served by an Openreach line will be aligned to MPF connection products re-using existing Left-In-Jumpers (currently priced at £11.24) + FTTC connection pricing
so if i understand correctly its £11.24 rather than £19.99 line rental
Re: SOGEA
19-05-2018 1:56 PM
Re: SOGEA
19-05-2018 1:56 PM
