Reverse DNS and Staic IP request
Moz905
1st line support saying I don't have a static IP but my connection settings say i do.  Looking to remove and move to dynamic IP please as also ensure rDNS is removed as lookup is showing my plusnet user name.
I don't think 1st line support fully understood the call so ticket is similar to others on here and my reference is 233889071
3 REPLIES 3
Moz905
Re: Reverse DNS and Staic IP request
Router has been restarted as requested but still hanging onto the static IP
Fixes: 1,658
Hi @Moz905
Apologies for the confusion here, I've removed the static IP. If you can reboot your router again, you'll be on a dynamic IP and the rDNS of the static IP will update within 4 to 24 hours, removing your username.
Moz905
Perfect thank you Smiley
