Reverse DNS/PTR setup for static IP
OllyB
Hello,
I would like to get reverse DNS/PTR setup for two domains using my existing static IP address.  I phoned customer support but they were unable to help.  Could someone please point me in the right direction.
Many thanks in advance.
7 REPLIES 7
Fixes: 580
Re: Reverse DNS/PTR setup for static IP
@OllyB
You are in the right place, one of the PN help team staff will pick this up.
However, you can only have a single PTR record so you need to decide which domain you wish to use. Make sure that you have a corresponding A record pointing to your static IP
OllyB
@MisterW , thanks for your quick response.  Understood re: single PTR record, that shouldn't be an issue.
Tina11192
Fixes: 18
Hi @OllyB thank you for taking the time to contact us.
I have raised this task to our NetOps team, please see the link below for a more detailed response: https://www.plus.net/wizard/?p=view_question&id=245949001
Cri Ignatti
OllyB
Hello @Tina11192,
The ticket that was raised (referenced in your previous note) suggests that the reverse DNS should be set up within 5 working days - dated 4th February.  The task reference is RITM00479143.
The reverse DNS still points to 80-229-139-65.plus.com instead of to the domain.  I responded to the ticket on Tuesday to ask for an update and have not had a response.
Could you please let know how I can pursue this further.
Thank you
Tina11192
Fixes: 18
Hi @OllyB I tried calling you but could only leave a voicemail. My apologies for the delayed reply, I hope you are well.
I have looked into this and the task is showing as completed, I am unsure what has happened, however, I am more than happy to re-raise it; I have now responded to the question on your account, please reply at your earliest convenience.
Cri Ignatti
OllyB
Hi @Tina11192,
Thanks for your response.
I've responded to the ticket and confirmed the domain in the ticket.  Please let me know if there's anything else you need.
Many thanks
Tina11192
Fixes: 18
Thank you for your reply @OllyB I have re-raised this and updated the question on the account, please follow the link for a more complete response: https://www.plus.net/wizard/?p=view_question&id=2465949001
Cri Ignatti
