Request to change Reverse DNS - rDNS
shopcentric
Hello.
Can someone assist me with a rDNS change please?
12 REPLIES 12
SammyM
Fixes: 101
Re: Request to change Reverse DNS - rDNS
Hiya @shopcentric
We would be happy to help, what is it you need?
 Sammy M - Sheffield Team
shopcentric
OK thanks. I would like to change the rDNS on my static IP, I don't know how to do or how to open a ticket. Can you help with that?
willcutforth
Fixes: 113
@shopcentric sent you a text if you can just reply I can sort it for you Smiley
 Will Cutforth
shopcentric
Thanks Will. Reply sent. 👍
willcutforth
Fixes: 113
This has now been sent over to the team to get actioned for you Smiley Please give a few days and it will be sorted Smiley
 Will Cutforth
shopcentric
Thanks Will.
C_J
I have never worried about this but g-mail are now refusing to accept e-mails with my domain name of 24 years. The SPF entry is correct for Plusnet's outgoing mail relay, so it would appear that their grip is that my rDNS does not match my forward DNS.
Please can it be changed from username.plus.com ?
Colin
Tags (1)
Fixes: 581
@C_J If you're sending via the Plusnet relay, then your rDNS is irrelevant.
shopcentric
I would use mail tester to diagnose first:
https://www.mail-tester.com/
What does that tell you?
C_J
Thank you for that, it was most helpful. I had tired checkers that said all was perfect, mail-tester.com found an issue even if it did say I was basically fine.
My SPF was on mail.domain.co.uk as per what the rejection said, but needed to be on domain.co.uk as per the sender.
I have now left identical SPF records on both.
For others, it's set to "v=spf1 include:_spf-internal.plus.net include:_spf-internal2.plus.net ~all" which should get all of Plusnet's relays and be server-address change proof.
It appears that the DNS=rDNS check is done on the mail relay, and that passes. Your server's DNS would have to match rDNS if you are sending from your server and not going via Plusnet's relay.
Many thanks Dabbler - I can leave the rDNS as it is for now, unless they start checking that one too.
Buck_
i now have a static ip and would also like my rDNS changed to  mail.ryanmail.co.uk
thankyou
Tags (2)
LexLex2020
Fixes: 12
@Buck_
Sent that off for you, will be done in the next 5 working days.
Lex Keehner
