Request to Change ISP Tag
flam
After much consideration, I have decided to move my Domain and email to Mythic Beasts rather than Greenby.
Please, @plusnettony would you be kind enough to change the ISP tag on my domain "lam dot org dot uk" to "MYTHIC-BEASTS".
5 REPLIES 5
plusnettony
Fixes: 80
Re: Request to Change ISP Tag
Please log in to your account and reply to ticket 257080060. I'll have this done for you when I see a reply.
 Tony T
flam
Thanks @plusnettony
Stu07
I too have the same issue. I'm trying to move two domains away from Greenby mine and my wife's but as you say the button doesn't work and they don't respond to support tickets. How do I move the domains?
plusnettony
Fixes: 80
I've raised a ticket on your FNN account.
Please reply to 258534024 on the MAAF portal and I'll action - also note only one domain is listed on the account I saw, so we may have to repeat the process on a different account.
 Tony T
Stu07
Thanks Tony All fixed, I wouldn't have been able to do it without you well done
